LIP SEAL ON INTAKE
Old Nov 18, 2001 | 07:34 PM
86IROCTHD's Avatar
Car: 88 Trans Am
Engine: lt1 intaked 355 makin 277 on 25 psi of fuel pressure and stock timing :)
Transmission: A4 stock... that moved a mobile dyno a foot shifting into 2nd :)
LIP SEAL ON INTAKE
i know the seal is bad on my 86 IROC TPI at high RPM's it squirts oil out.... and SMOKES to high heaven... but its not out the exhaust..... think it could have been caused by blowby or just went bad.....had oil changed 2 days ago....have been racing it... and the oil is changing color already.... but also went over on my oil change... so could be washing tha old stuff off....... please help
305, TPI,compucam 2030 cam, air foil, 8.8 wires, accel super coil, dynomax headers, custom y-pipe, cut out, 80 series flowmaster, just installed my 3.08 posi disc brake setup...(3.42-3.73 on the way). and a stage 4 chip :0). hittin a sad 15.1 after the chip with 2.73 open diff....
Old Nov 18, 2001 | 07:45 PM
rezinn's Avatar
Which seal? The front or back intake manifold to block? Where does the smoke come from and what color is it?
Old Nov 18, 2001 | 07:49 PM
86IROCTHD's Avatar
Car: 88 Trans Am
it leaks down the front passanger side up front......and hits the y-pipe and makes a nice CLOUD... people think i spray N2O cause if it lol.... but dont like the looks and smell....esp. when there is a fine chick in the car.....
Old Nov 18, 2001 | 08:09 PM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
Must be a pretty bad leak. I had that problem for months and never burned any oil on the headers or Y-pipe. Just saw a nice trail of oil down the front and back of the block and all over the drivetrain.
92 Camaro RS, LO3, 5-spd, T-tops
Performance:
K&N Open Air Filter, Edelbrock performer TBI intake, Fastchip Prom, Timing +4 degrees, Centerforce clutch, Xact 8mm wires, SLP 1 3/4" Headers (coated), Flowmaster Catback Exhaust, Richmond 3:42 gears, Torsen HD Posi
Sights & Sounds:
Alpine 8030 Alarm System, Valentine One Radar Detector (How did I ever drive without one?), Pioneer DEH 7450 Head Unit w/6-pack CD changer, Pioneer DEQ 7600 Sound Processor, 2 Kenwood KAC-846 Amps powering 2 12" Pro Red subs, 2 Pioneer 6x9 and 2 MTX 4x6 speakers. Z28 grille w/aftermarket lights, MacEwen whiteface gauges
NEXT UP: TBI & Suspension mods
Old Nov 18, 2001 | 08:12 PM
86IROCTHD's Avatar
Car: 88 Trans Am
well my y-pipe hangs REAL low...... so
92projectcamaro
Jan 18, 2016 08:00 AM
86CamaroDan
Sep 29, 2015 10:08 PM
Dialed_In
Aug 20, 2015 01:45 PM
86White_T/A305
Aug 17, 2015 12:16 AM
