fuel rail help
Old Oct 22, 2005 | 05:09 PM
85ta4bm's Avatar
Car: 85 trans am
Engine: 350 4bm TPI
fuel rail help
hello, i have an 85 trans am 350 TPI and i'm trying to take the fuel rail assembley off i took the fuel line fittings and bracket disconnected the injector wiring harness, cold start valve, and the 4 mounting bolts and the next step in my book saysremove the fuel assembly but it won't come off, i didn't want didn't want yank it out and risk breaking the injectors, and i tried spraying wd40 around the injectors at the manifold, but it's still stuck on, any ideas are greatly appreciated...
Old Oct 22, 2005 | 05:56 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
I just yanked mine and it popped out after a while. I had the same fears of breaking it, but I realized I'm using a new intake and injectors so I didn't care. I didn't do any damage though, just pulled each set of 2 straight out and they popped out.
Andrew6.688
Dec 13, 2015 10:59 AM
stalkier
Dec 6, 2015 11:25 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
92projectcamaro
Aug 6, 2015 01:20 PM
