help with codes
Old Oct 23, 2005 | 01:11 AM
jethawk's Avatar
Car: 1991 Firebird Formula WS6
Engine: LB9
Axle/Gears: 3.42's
help with codes
was driving the car around.. and the SES light came on for the following 2 things...
43. Low voltage at electronic spark timing circuit
46. Fault at vehicle anti-theft sytem OR
Fault at power steering switch
am i dealing with 2 seperate problems... or are these in someway connected to each other?
thanks... Ben
Old Oct 24, 2005 | 03:39 AM
azvolfan's Avatar
Car: currently thirdgenless!!!
I doubt they are related. Code 46 is a vats problem. And the code 43 means you could need a new EST.
Old Oct 24, 2005 | 03:55 PM
jethawk's Avatar
Engine: LB9
Axle/Gears: 3.42's
got it fixed... 46 was an old stored code... and the 43 was from the knock sensor wire shorting out.... re-ran a new wire and its all good!
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
