How to fix the trip meter?
Old Nov 18, 2001 | 08:38 PM
88blkiroc's Avatar
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
My trip meter hasnt worked since I bought the car. The odo works still, but when i hit the reset button for the trip it just kinda flops around to whatever numbers it feels like and goes from there. and not necessarly in any sort of order. it likes to count by tens and hundreds anyone got a fix for this? id like to get it working. thanks.
1988 IROC-Z L98
Engine Mods:
Edlebrock TES Headers, Hypertech Chip, Flowmaster Muffler, Intake Airfoil, AFPR, MSD-6A, MSD Blaster 2 GM Coil, bored .030 over.
Nitrous System:
NOS Dual Fogger Nozzle Setup, Jetted @ 150hp.
Suspension Mods:
Lakewood Traction Action Lift Bars, Hal Rear Shocks
Trans Mods:
2,500 stall converter, Redline clutches,Heavy Duty Steels, Trans-Go reprograming kit, Heavy Duty 2-4 band, Corvette Servo, B&M Mega Shifter
ET: 13.833@99.30 N/A
No Juice Times Yet.
"Man you should put 2 bottles in, youd go faster" Nitrous advice from a 12 year old Fast and Furious fan.
www.mfba.org
Old Nov 18, 2001 | 08:55 PM
Macgyver's Avatar
Sounds to me like someone beat the hell out of it, if it's anything like a dodge speedo (the only kind I've ever seen disassembled) You're pretty much screwed, the teeth on the gear are probably null and void.
Old Nov 18, 2001 | 09:00 PM
88blkiroc's Avatar
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
anywhere i can get a replacement unit from?
Old Nov 18, 2001 | 10:22 PM
89BlwnRs's Avatar
I remember hearing about this on this board before. It seems one of the gears that conrols the odomoter is made of plastic and is prone to breakage. Replacing that gear should solve your problem. I don't know if GM sells that as a part, if they don't find a speedo in a junkyard and pull it's gear.
Jason
Old Nov 18, 2001 | 10:30 PM
88blkiroc's Avatar
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
ya but the odo works, its the trip thats messed up.
Old Nov 19, 2001 | 03:19 AM
Jza's Avatar
Jza
On the two that I've seen, it wasn't a gear or any teeth, it was the hole that the wheels' axle goes through. So the whole assembly has enough play to be pushed back and the gears jumps a tooth, which is why some catch and some don't (turning seemingly random numbers). I never fixed it, I just switched to a digital cluster.
Old Nov 19, 2001 | 06:33 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
As I recall, there are two small and very fragile plastic 'hooks' that hold the roll in place. When they broken, the roll is free in the housing. At any rate, the problem is common.
JamesC
92firebirdguy
Sep 1, 2016 07:53 AM
L98GTA87
Oct 19, 2015 10:43 PM
Shane87irocz
Sep 22, 2015 06:21 PM
sahlomonic
Sep 20, 2015 07:15 PM
eustodp
Sep 20, 2015 05:09 PM
