Bought an LT1, converting to carb- within.
Old Nov 15, 2001 | 08:56 AM
Brandog87GTA's Avatar
Well we got a hell of a deal on a 95 LT1. The motor costs us 600 dollars for everything, starter and all. GM is the only company that makes a carburator intake for these style aluminum heads. We are using that manifold with an HEI distributor and perhaps a zz9 cam. Anyone have any suggestions on this combo??? Camshaft ideas that might make more power. I have heard those motors will instantly make 350 HP just by converting to carb.
Bright red 87 GTA with I have stock 3.27 gears,2200 stall,B&M shift kit, TRW forged 9.75:1 pistons,comp cams pushrods, edelbrock valvesprings, 462 camel hump heads with 2.02in/1.60ex redrilled for angled plugs, 3 angle valve job, ported and polished, performer RPM intake, mallory fp regulator, edelbrock 750 CFM carb, hei ignition(new) with 40,000 volt coil,No cat, flowmaster 1 chamber mufflers, hedman 1 5/8 full length headers, edelbrock cam with 488/501
Best Run 1/8 mile 8.62 at 84MPH on street tires, Consistantly run 8.8. 60 foot times 2.3
Old Nov 15, 2001 | 10:09 AM
Inwo's Avatar
Car: 2007 Saturn Sky Redline
Engine: 2.0 turbo
Transmission: m5
Axle/Gears: 3.91 LSD
Wow I didn't even know that was possible...
Old Nov 15, 2001 | 12:33 PM
BitchinCamaro's Avatar
Yeah, how the #ell do you do that? I didn't think the block had provisions for a stock style distirbutor.
Old Nov 15, 2001 | 12:52 PM
Yeah, u can run a distributor on one. The manifold you buy comes with the hole cut out for the distributor. The lt1 uses the same style cams as the l98. It will be able to drive the distributor.
Old Nov 16, 2001 | 11:02 AM
RSR's Avatar
RSR
I have run a carb'ed LT1 for about 2 years now, and I'm pleased with it. I have a stock LT1 bottom-end, with:
- LT4 heads
- LT4 HOT cam kit
- HEI
- GM dual plane intake
- 750 Demon Mech Sec carb
- 1 3/4" shorties
I run a modified-for-racing 700-R4, with lockup provisions. The converter is a 10", about 3000 stall.
It runs on pump premium. The car runs 12.20's-30's on motor. It is running 11.40's on a 100-shot of nitrous. I 've just jetted it to a 150-shot, but haven't made any good passes yet, although I did just smoke a new Vette running a 150-shot.
Anywho, it's a great combination. I don't think you'd give up too much sticking with the stock heads. The HOT cam is nice, and the package, which includes the cam, springs, and roller-rockers is a steal from GM at about $450.
Once I lock the converter up on the interstate the car gets 17-19 mpg. It gets probably 10-12 around town without the converter locked....
RSR
Old Nov 16, 2001 | 11:17 AM
Wow thats some fast times. What are you 1/8th miles times and MPH??? Lt4 cam sounds like the way to go. I assume those times are on slicks. Did you run into any problems??? Stock bottom end??? I would be happy with high twelves from the motor.
Old Nov 16, 2001 | 02:29 PM
DAVECS1's Avatar
Car: 91 GTA
Engine: 377ci
Axle/Gears: QP Ford 9" 3.70s
Do you guyd still hve the LT1 plenum and all of the goodies that go along with it? I would be interested in lifting that of your hands.
91GTA 5.7liter needs paint, I rebuilt the trans, engine is moded but old
Old Nov 16, 2001 | 07:13 PM
RSR's Avatar
RSR
Brandog, it runs 7.75-.85 1/8th mile. I'm still working on the right way to launch. It runs quicker if I flash the converter rather than power-brake it, but is a little less consistent.
All of the times mentioned are on Mickey Thompson Sportsman Pro tires, not slicks. I think it would go slightly faster on slicks, but not make a huge difference. I wanted to set it up to be able to drive it to work, home, and straight to the track.........which is what it does!
One thing I've learned is that the motor does not need real steep gears.........
I used to have a 2400 stall converter from SLP and 4.11 gears, and it ran 12.80's on the motor.
RSR
Old Nov 17, 2001 | 10:59 AM
RSR's Avatar
RSR
DaveCS1, yes, I have the intake manifold and various parts. Email me at ryanreed@lexmark.com to discuss further....
RSR
Old Nov 19, 2001 | 07:32 AM
I have all kinds of LT1 intake stuff also, fuel rail, intake, DIS, coil packs. Everything is being sold except for the starter and alternator.
midge54
Dec 27, 2019 04:14 PM
69 Six Pack
Oct 5, 2015 07:51 PM
86IROC112
Sep 7, 2015 01:37 PM
johanlindgren
Aug 16, 2015 12:16 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
