question about noise at high speed...
Old Nov 17, 2001 | 11:01 PM
Blade69's Avatar
i just got my 84 camaro a couple of days ago and when i reach 70mph the car starts shakeing and gets real loud. I just got new tires and got it realied and it steal does it. Is this normal for camaros? the shifter *** also starts raddeling like crazy.
Old Nov 17, 2001 | 11:54 PM
Enkil's Avatar
Hmm. Could be a few things.
Very badly balanced tires.
A driveshaft in need of a balancing.
A REALLY horrible engine. heh.
Does the engine shake a lot when it's in neutral at high RPM's?
And, here's a very dangerous way to test if it's the driveshaft or not:
Put the rear of the car on jackstands so the tires are off the ground, put the car in drive, and rev it up. Be sure the jackstands are clear of the tires. Again, this isn't the smartest thing a person could do. heh
89 iroc-z 305 tbi
k&n filtercharger, open element air filter. nuffin' else
Old Nov 19, 2001 | 11:25 AM
nestz28's Avatar
I would have to say it's the driveshaft because of the shaking shifter ****, that's the logical next step to check since you said you got new tires with no difference. A possible easy fix is try making sure there is no dirt or any foreign matter on the driveshaft that would throw it out of balance.
theshackle
Sep 17, 2020 08:26 AM
xxx3man`
Sep 23, 2015 10:37 PM
B_Dubya
Aug 26, 2015 05:09 PM
Fronzizzle
Aug 19, 2015 01:36 PM
redmaroz
Aug 16, 2015 11:40 PM
