Why do I have oil coming from head bolts??
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
How does that happen? I thought they only went into the coolant passages?
you sure it's coming from them and not dripping on them? only way you could have oil coming from a head bolt is oil getting into the coolant and then have a leaking head bolt too, 2 imdependent events
Right; all 34 go DIRECTLY into the water jacket. It is not possible for oil to come out of them unless you filled your cooling system with oil. (don't laugh... it's been done before.... OK, go ahead and laugh now....)
What type of sealer did you put on their threads?
Engine: 355
Axle/Gears: 4.11
I used white teflon thread sealant last time. Maybe I didn't use enough or something is cracked? Block or head damage? The valve cover was still tight and the gasket was good.
It just looked like the oil was oosing from the bolts. Quite a bit too. I've never heard of anything like this before.
Engine: 355
Axle/Gears: 4.11
oops, they were the bottom row, short bolts that were leaking.
W/ ARP hardware do you guys run the motor and then retorque the heads? Or tq them once when assembling them and go w/ it?
I just build it and drive it. I can't remember the last time I re-torqued a head.
New cars don't need it; correctly rebuilt ones shouldn't either.
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
i asked that ? once about re-torquing head bolts after a break-in and got a unanimous NO. if you retorque, it'll disturb the thread sealer, and if properly torqued, shouldn't need re-torque. so i left mine alone cuz i know i torqued them right, but i had a leak before that i'll have to check later - when it's running again...
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Originally posted by Free Bird
What do you tq al. heads to? 65 ft lbs?
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Sure it wasn't oil under the head bolts from when you adjusted rockers? Leaking valve cover? Could just be oozing if solvent wasn't used to blow off the residue. Hopefully it will not continue to oozze.
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
All GM aluminum heads that I've dealt with (pre-LS1) require 65ft-lbs, applied in 3 equal stages. I do 22-44-65 personally, though you don't have to be that exact with things (i.e. 20-45-65 will work fine as well, as long as they are 3 fairly equal steps)
355tpipickup
Aug 25, 2015 12:54 AM
Navy8125
Aug 21, 2015 09:32 AM
