timing noob
Old Oct 25, 2005 | 08:07 AM
Bobbyz's Avatar
Car: 87 IROC Z "ZZ4"
Engine: 350 "ZZ4"
Transmission: ck performance th400 3000 stall
Axle/Gears: 3:73 10 bolt
timing noob
Can ne1 help me get my timing sorted out?
i know how to set the initial timing i got that at 12* at 800 rpm vaccum disconnected im trying to get 36* at 3200 rpm
i installed a crane cams adjustable vaccum canister and also put in blue springs.
car runs good but i wanna make sure about the total.
motor is a zz4 carbed 350
thanks
Old Oct 25, 2005 | 12:18 PM
Damon's Avatar
You have to disconnect the vacuum advance (temporarily) and rev the engine up while shooting the timing light. Somewhere around 3000 RPMs or so the timing should not advance any more. THAT'S where it should be 36* or whatever you're trying to set it at. Advance or retard as necessary to hit that mark. Having a degreed dampener or a dial-back timing light is necessary to do this.
Wherever that leaves your initial timing (base timing at idle) that's where you leave it. Plug you vacuum advance back in.
Many V8 HEI distributors have about 20* of centrifugal advance built into them (don't take my word for it- MEASURE yours, per the above procedure). That means that at 36* total timing your initial timing will drop back to about 16* at idle (36 - 20 = 16).
Old Oct 25, 2005 | 01:11 PM
Bobbyz's Avatar
Engine: 350 "ZZ4"
Thanks.
so what i need to do is rev the motor up to 3200 rpm then turn the distrib to get it to 36* then where ever it falls back to intial just leave it?
Old Oct 25, 2005 | 02:23 PM
dennisbernal91z's Avatar
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
I have a quick super noob Q. How does the degree reading help? Aren't they spinning around when the motor is on? So how do you see them? I don't get it. Thanks.
Sorry if this is a hijack of the thread, I figured you guys can quickly answer it and get back on topic, thx.
Old Oct 25, 2005 | 03:18 PM
Bobbyz's Avatar
Engine: 350 "ZZ4"
Timing light
Old Oct 25, 2005 | 08:03 PM
flaming-ford's Avatar
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
Axle/Gears: 10 bolt 3.08 posi (4 now)
you will just see the mark a little ways away from the timing marks with a timing mark. Remember a circle is 360*. In other words 36* should be easy to hit and see from the top with a timing light.
Old Oct 25, 2005 | 09:34 PM
Engine: LS3
I know you guys are trying to fill me in and I thank you for that, but I really need the "explaining it to a girl" kinda expenation. I have built 99% of my car, and I learn everything as I go, I am getting a new motor within a week and am gonna learn how to tune it and buy a timing light and stuff then, I was just posing the Q to get a head start.
I do not even understand how u use a timing light. I know what it does and how to adjust timing and syuff, but litterally how do u point it and what do you eyes see and that kinda thing.....
Old Oct 25, 2005 | 09:39 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
You hook up the timing gun, positive and negative battery terminals, then the lead on the respective spark plug wire (usually the #1). You aim at the timing tab and pull the trigger. The light flashes whenever the plug fires. When the light flashes, it will light up the timing tab (quite brightly) and you will see an etched line on the balancer. It's correlation to the timing tabs markings is used to determine the timing.
It works along the same lines as a stroboscope.
Old Oct 26, 2005 | 06:49 AM
Engine: LS3
Very Nice!! thanks for the walk through. That is exactly how I thought it worked. Thanks again.
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
