What to do about knock sensor?
Old Nov 20, 2001 | 02:02 PM
MotorCityMuscle's Avatar
I am looking at an 83 z-28 with an LG-4. The engine harness has seen better days so Im thinking I would rewire it with a harness from an 84 Z-28 with an L-69. My question is, what to do about the knock sensor wire in the 84 harness? The 83 LG-4 would have no knock sensor, right? Iv heard stuff about using a resistor and Ive also heard to just not hook it up and the computer won't care. What do I do?
Old Nov 20, 2001 | 02:18 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Put in a knock sensor if you use the L69 computer. If you use the 83 LG4 computer, it doesn't know anything about a knock sensor anyway, so just tape the wire back into the harness.
If you use it, it screws into the block where the pass side coolant drain plug goes.
ICON Motorsports
Old Nov 20, 2001 | 10:29 PM
So I could use the 84 L-69 harness with the 83 LG4 computer? What are the difference between the two ECM's? The L-69 has a little better timing curve is all I've heard.
L98GTA87
Oct 19, 2015 10:43 PM
cking99
Sep 22, 2015 11:33 AM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
BLK87Z
Sep 18, 2015 11:29 PM
FormulasOnly
Sep 10, 2015 09:07 PM
