Open Throttle in First gear, woops....
Old Nov 20, 2001 | 09:04 PM
ChevyLuva3's Avatar
I was drivin my sis's '00 Grand Cherokee the other day. I was comin from a stop sign, mergin on to the road. After I get on the road I floor it, then I hit Open Throttle. All of a sudden the car starts rockin back and forth, I'm like what the fvck?! Felt like anti lock brakes, but worse. I look at the gear, oh ****, its in First! WOOPS! I guess when I pulled the gear down (from reverse, getting out of parking spot), I must have pushed the button in by accident. And instead of dropping into D, I dropped into 1. So I let off the gas, changed it back into D. Whew. So what was the rocking back and forth, was that the Rev Limiter? What was that?
Old Nov 20, 2001 | 10:19 PM
Buck268's Avatar
I did that in my dad's crwon vic when I turned sixteen. 50 mph down a dirt road in 1st...interesting....
Old Nov 20, 2001 | 11:19 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
Yeah, I would say that it was most likely the rev limiter.... If that vehicle was a little smarter it would have upshifted for you - a lot of GM transmissions will actually ignore the shifter position and upshift the transmission if it is accidently left in too low of a gear and you keep bouncing off the rev limiter.... But Chrysler can't make a decent transmission to save their lives, so.......
1987 GTA L98 MD8
355, TFS Heads, LT4 Hot Cam
My GTA
The Minnesota F-body Club
jklein337
Sep 19, 2018 06:23 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
