What size belt do I need?
Anybody here running a v-belt running around crank, water pump, and alternator.
I'm using standard pulleys on everything, and a standard passenger alternator bracket.
Anybody have their reciept from PepBoys or Napa or TrackAuto or whatever saying the size of the belt so I don't have to guess and check?
Mine flew off on a 6500rpm nitrous pass and it's nowhere to be found
'90 GTA...nitrous is your friend
Does anyone know what the number of the standard serpentine belt for an 88 Camaro 350 TPI engine? I found that Dayco 968K6 is the number to use if you remove the smog pump, but need to know the number of the standard item.
