327 heads on 305?
Old Oct 27, 2005 | 01:31 AM
htberlinetta84's Avatar
Car: 1984 camaro berlinetta
Engine: 305 4bbl.
Transmission: th700r4
327 heads on 305?
i was just wondering if someone could tell me wether or not you are able to put 327 heads on a 305 not HO? any information or links would be greatly appreciated. Thanks
Old Oct 27, 2005 | 02:05 AM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
Sure, they'll bolt up. Without knowing what casting they are, I can't tell you any more about them. Someone else may be able to though, I don't know much about the older motors.
Old Oct 27, 2005 | 02:11 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
They'll bolt to the block, but chances are they won't have bolt holes to mount your accessories. The valve seats probably aren't hardened for unleaded gas either.
Old Oct 27, 2005 | 06:14 AM
ede's Avatar
ede
and after near 40 years there might be a bit of wear on them
Old Oct 27, 2005 | 12:32 PM
Engine: 305 4bbl.
well guys, thanks for the quick replies. i do not have the 327 heads yet, i was hoping i could get more information as to what casting numbers to look for. also if you know anyone that has done this maybe get their casting numbers? lol, its a longshot, i would just like to know if it will owrk. maybe it would just be easier to stick some 350 heads on it? that would work, correct me if im wrong but i think its been done
Old Oct 27, 2005 | 01:01 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I wouldn't look for any 327 heads, regardless of casting number. Most 350 heads are going to have larger chambers which will kill your compression on a 305.
Old Oct 27, 2005 | 01:04 PM
JOHNNY WALLACE's Avatar
Car: '86 pont. t/a convertible
Engine: '66 vette 327
Transmission: turbo 350
It will work ! But I have a 1966 vette 327 - no bolt holes in front of heads.Will have to make altered brackets.
Old Oct 27, 2005 | 01:14 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Like a lot of things that will work, they're probably not worth the trouble.
Old Oct 27, 2005 | 01:48 PM
Engine: 305 4bbl.
hmmmm, alright, wlel it was just a thought. figured it would work one way or another but i suppose your right that its not worth all the work. would you suggest port and polish on my stock 305 heads? or go performance?
Old Oct 27, 2005 | 01:50 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
port and polish your 305 heads = performance
if you want more, go for a 350. otherwise your just throwing good money at a bad motor.
Old Oct 27, 2005 | 01:51 PM
Sonix's Avatar
Car: 1982 Trans-Am
oh yea, welcome to the boards, hows medicine hat treating you?
Engine: 305 4bbl.
well for affordable gas issues i think i'll be sticking with the 305, lol. thanks for your help and suggestions everyone.
Edit: lol medicine hat sux, boring. quite. thats why i work on my car, lol.
Old Oct 27, 2005 | 02:32 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
327 heads would drop your compression, since the stock 305 head chamber is 58cc (unless some are bigger like hmm 64 ???)
I was going to get some other heads but considering some people have had excellent results from porting their swirl port 305 heads ... oh well .... I'm going to do the same
And welcome to the "I'm going to stick with my 305" club Sometimes not enough of us
Jake_92RS
Jan 28, 2020 10:37 PM
gta90
Sep 15, 2015 04:00 PM
Mickeyruder
Sep 2, 2015 02:45 PM
theurge
Aug 21, 2015 12:46 PM
