what kind of intake bolts for aluminum heads??
Old Oct 27, 2005 | 11:06 AM
roughskinjrz's Avatar
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
is there a certain set of studs or bolts i should use for my intake??
im running trick flow aluminum heads and an edelbrock rpm air gap intake, i was just going to use stock steel bolts with a washer? is this ok?
or should i purchased some arp stud kits for these?
i just had a few people get me thinkin about bolts i should be using
thanks in advance
Old Oct 27, 2005 | 11:42 AM
1983Fbody's Avatar
Car: transam, el camino
Engine: 415
You'll be okay using steel bolts in aluminum, what other kind is there? Just be sure to use some kind of thread anti cease on the threads that go into aluminum, otherwise the steel has a tendency to bond with the aluminum and pull threads when you go to take them off.
edit- I like to use the stainless steel alan head bolts from the hardware store, the smaller head size fits better around some holes in the manifold and they look better.
Old Oct 27, 2005 | 12:41 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Use stainless steel with aluminum. You'll need a thread sealer, not anti-seize.
Old Oct 27, 2005 | 02:00 PM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
ok i have steel bolts, but i had to get the head machined, becuase of an intake leak, the china wall gaskets, and when i did i stripped the bolt and aluminum came off with the bolt, like what you said, i will use thread sealant like you said, anti seize, cost me 40$CAD, both holes in the back of the head for the intake were stripped and on an angle.
thanks for the help
Old Oct 27, 2005 | 03:00 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Which aluminum heads do you have? A lot of them come with the bolt holes helicoiled from the factory.
midge54
Dec 27, 2019 04:14 PM
Reddeath210
Oct 6, 2015 08:20 AM
355tpipickup
Aug 25, 2015 12:54 AM
Navy8125
Aug 22, 2015 07:13 PM
86White_T/A305
Aug 17, 2015 12:16 AM
