Missfire underload, tried EVERYTHING
Old Oct 27, 2005 | 08:01 PM
85z28guy's Avatar
Car: 85' Z28
Engine: 383 roller
Axle/Gears: Ford 9" 3.70
First things first, when I rev up the engine under no load, it is flawless. When its in gear, it goes alright until about 2500 rpm, and then it sounds a lot like a miss in a cylinder. I thought that maybe it had something to do with the old junk yard distributer, so I replaced the WHOLE igniton system. I even upgraded to a billet distributer, put on 8.8 mm wires, and a 50,000 volt coil. It runs better, but still does it. If I lift my foot it levels off, but the miss is still there. I adjusted the carb the best I could, and even borrowed a carb from a similiar setup. If I retard the timing it seems to run better, but still does it.
Old Oct 27, 2005 | 08:28 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
EGR?
Old Oct 27, 2005 | 09:15 PM
85z28guy's Avatar
Car: 85' Z28
Engine: 383 roller
I don't have an egr valve I got the timing gun out for like the 100th time, retarded it a few and it was near perfect! I have never had a motor that was this sensitive to timing. Hopefully it wasn't just a fluke, as I ran outta test time cause the neighbours bitch about the noise (even idling )
Old Oct 27, 2005 | 09:20 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
Have you verified the timing tab is the correct one for the balancer, i.e. does the mark on the balancer show 0 deg on your pointer at TDC?
Old Oct 28, 2005 | 03:57 PM
85z28guy's Avatar
Car: 85' Z28
Engine: 383 roller
Yup. It seems it was actually a combo of the motor AND my tranny, the converter is cooked I got the tranny built, but didn't put in a good converter yet because I wasn't sure how wild the motor was gonna be, or if I was gonna spray it. I'll get her sorted out
Old Oct 28, 2005 | 04:44 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Whats the mechanical advance setup on the distributor? stock springs and weights? How much timing are you running? Are you sure your balancer is accurate?
92camaro350cci
Oct 14, 2015 09:29 AM
Hellbillydeluxe
Sep 22, 2015 09:58 PM
camarohelp
Sep 22, 2015 03:19 PM
rubbermanZ28
Carburetors
21
Dec 19, 2003 04:27 PM
Jer82Z28
Carburetors
Aug 25, 2003 10:17 PM
