is this normal?
Old Nov 21, 2001 | 12:03 PM
tacoboy's Avatar
is this normal?
Okay, heres the deal. I just got done changing my oil on my new engine, 550 miles on it. The oil came out looking fine, but when I took off the filter, it didn't pour out the sides as I unscrewed it, like usually happens to me. It had oil in it still, which I poured out after I unscrewed it all the way. But everytime i have changed oil before I have gotten it all over me when removing the filter. I guess the car was cold when I changed it and that could have caused it, but it sorta worried me. It also took a little bit, like 5 seconds or so, to build oil pressure, is that normal too? I'm just sorta worried here and would like to know if I have an oil flow problem. Thanks.
Old Nov 21, 2001 | 01:41 PM
breathment's Avatar
when u put the oil filter on did u fill it with oil? or was it empty. and what kinda filter were\are you using?
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series Muffler added to Unkown CatBack, Ported Intake
http://www.geocities.com/david_angel_16
[This message has been edited by breathment (edited November 21, 2001).]
Old Nov 21, 2001 | 01:49 PM
tacoboy's Avatar
I think you are talkin about the one I took off just now, as in the original filter. That one, no we didnt fill with oil, just oil around the gasket thing. Same with the one I put on just today. They were both fram filters.
Old Nov 21, 2001 | 01:58 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
1. If you use a Fram filter, then it's normal for there to be no oil spilling out the top of the filter because Fram filters are such pieces of crap. If you were using a better filter, it might have an anti-drainback valve in it. But that Fram garbage doesn't, so after the engine has been sitting for a while, all the oil that's in the passages in the motor drains back into the pan by running backwards through the filter, taking all the filtered-out debris back into the pan with it.
2. Don't use Fram filters. They're crap.
3. When you install a new oil filter, pour a quart of oil slowly into the center of it to fill it up before you put it on. That way the engine doesn't have to run without oil for however long it takes for the oil pump to fill the new filter up with oil, instead it has oil as soon as it starts up.
4. Use some other kind of filter besides Fram. AC/Delco (PF35 or PF1218) is a far superior product to Fram crap.
ICON Motorsports
[This message has been edited by RB83L69 (edited November 21, 2001).]
Old Nov 21, 2001 | 02:04 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I've always used Fram and there has always been oil pour out the sides. I'm don't know whether that is anything to worry about though. And I just switched to AC Delco, I would have last time, but the store didn't have any.
"Putting any amount of money into a RICE BURNER is like wiping your a$$ with a turd. "
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
3" Hooker CatBack w/Aero Chamber muffler
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat, just switched to 180* b/c of winter coming and going to college in the mts.
3:73 Posi
Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
Old Nov 21, 2001 | 02:18 PM
tacoboy's Avatar
Alright so this is the way I see what you are telling me...I'm cool to drive it till next oil change, but next oil change use a real filter like AC huh?
Old Nov 21, 2001 | 04:26 PM
tacoboy's Avatar
Hmm okay, fram are deffinately crap. I for one am never buying another one again. That one I put on this morning failed within 5 miles of driving, that was fun. I got to change my oil again. Anyway, wasn't really the new filter's fault, mostly mine, but my part would have been circumvented by a quality filter. Anyway, the old filter's seal ripped off in the filter adapter, and from where I was when I was doing the first oil change I couldn't see. It came off hard, but I just figured my dad had put it in hard the last time. So when I put the new one in I wasnt surprised that it was hard to tighten. Little did I know that I now had a double seal. Stupid Fram, you've lost a customer. Anyway, my vent is over, you guys were right.
Fanatic1074
Oct 3, 2022 05:57 AM
Linson
Oct 1, 2015 09:50 PM
Giocio
Oct 1, 2015 12:20 PM
dusterbd
Sep 29, 2015 08:40 AM
BWilcox
Sep 20, 2015 12:19 PM
