Loss of top end
Old Nov 21, 2001 | 10:42 PM
HrdRockA4305's Avatar
Loss of top end
Hey guys, gotta small problem here.
For the last few months, my car has been making absolutely NO power above 3500 RPMS at all. It used to pull strong to 4300 or so. It'll rev that high, but has no pull at all, and still shift around 4500 at WOT, just take FOREVER to get there. You can really feel it, like somone hit a switch, and the power is just gone. Anyway, as of yesterday, it has brand new cap, rotor, wires, plugs, and O2 sensor so i doubt its any of those things, but it didn't help. All the plugs were clean, just a nice light brown tint with no fouling or oil built up.
At all other RPM ranges if feels pretty strong, and is still pulling 20 MPG when i'm easy on it. I also usually do get a check engine light after about 5 minutes of driving, but it hasn't done that all day today, though it did on the drive home after the tune up parts were installed. I know i need to scan the error code, but the problem occurs regardless of the SES light being on or not.
Any gurus have any suggestions? I think I'm gonna post this in the TBI board too just to hopefully get the most responses. Thanks to anyone with any tips!
88 Camaro (The mighty LO3 SC!)
305TBI/700R4/2.73/125,XXX miles
10" Open Element and Flowmaster 80 seires
Bosch Platinum plugs
Double silicone Accel wires
Next up: headers and gears
Old Nov 21, 2001 | 10:47 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Maybe a clogged cat. Any other symptoms, maybe running a little warmer than usual or maybe check to see if the cat is glowing.
"Putting any amount of money into a RICE BURNER is like wiping your a$$ with a turd. "
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
3" Hooker CatBack w/Aero Chamber muffler
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat, just switched to 180* b/c of winter coming and going to college in the mts.
3:73 Posi
Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
Old Nov 21, 2001 | 11:22 PM
Oh DUH i forgot about that! Actually it rattles like hell when your not moving. The back brick looks brand new, we looked at it while i was having the cat back put on, but i think the front brick is busted into a million pieces. If its turning into dust n stuff it could be clogging... i dunno. Its going bye bye when i put the headers on anyway, maybe i should drill it out before it gets worse. It runs fairly cool right now but usually got to about 230 in the summer and would stay there, not bad i guess but it wasn't doing it as much then.
customblackbird
Aug 15, 2021 10:16 PM
Street Lethal
Apr 30, 2019 12:14 PM
SiCkRs
Members Camaros
32
Jul 1, 2018 04:53 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
