This is different
Old Nov 21, 2001 | 10:20 PM
BlueRoc's Avatar
This is different
Fired up the Iroc last week and went to town
15 miles away, no problems. Came out of the store, fired her up and she started missing
and sputtering at 3500 and above. Next day back to town, no problems. Next start-up same thing as before at 3500 and up. Anybody
have any ideas?? The first start-up I can run it to 5000 rpm and absolutely no misses,
sputters, or farts. Any start-ups after that
and it does its dance. I have let it set in between starts for up to an hour but still have the same problems. Thanks for any replies. Have a Good Turkey Day!!!
1990/Iroc/305 TPI/T5
Hooker Cat-back
K&N Filters
Old Nov 21, 2001 | 10:54 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Burnt or fouled plug wires. Clogged cat. Just a couple of guesses.
"Putting any amount of money into a RICE BURNER is like wiping your a$$ with a turd. "
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
3" Hooker CatBack w/Aero Chamber muffler
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat, just switched to 180* b/c of winter coming and going to college in the mts.
3:73 Posi
Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
Old Nov 22, 2001 | 03:13 AM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
You may have a problem with the fuel injector coils shorting out internally when they get heat-soaked and one or more of them are intermittently not firing correctly - or at all. It is not uncommon for TPI injectors to do this, depending on the type of injector.
An idea......
Good Luck! Happy Thanksgiving!
1987 GTA L98 MD8
355, TFS Heads, LT4 Hot Cam
My GTA
The Minnesota F-body Club
