New Motor but burning More help!
Old Nov 21, 2001 | 03:17 PM
Brian Felts's Avatar
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
Ok I have checked the PVC and it is in a baffled hole. The Vortec heads are unmodified except for milling them and affing .500 lift springs. I am running the LT-4 cam with .476 I and .480 exhaust. Could the rocker hitting the valve guides cause the oil smoke from the exhaust. I did have about .025 take off the heads to lower the chamber CC's could it come from the bottom of the intake. I have not done a compression test yet. The car seems to smoke evenly at idle and reving, seems to smoke more as it warms up.
Thanks for the input
Brian Felts
1989 Camaro RS
305 .030 over Hydro Pistons
Vortech heads milled to 58cc...Performer RPM intake....LT4 cam..Crane Gold rockers...FastChip custom chip...ALum. Driveshaft...3.73 gears with Posi...underdrive pullys...Rebuilt 700R4 with Vette Servo and B&M shift Kit...MSD ignition...A/C Delete No SMOG junk....1997 SS leather interior...B&M Shifter... Ultimate TBI mods...14X3 K&N open Element Non-Drop...Hooker headers....3" exhaust with Flowmaster Cross flow 16X8 Wheels from 97 RS Spohn LCA's Spohn Panhard Bar..LETS PLAY FORD!!
www.geocities.com/feltsb
Old Nov 21, 2001 | 03:34 PM
DM91RS's Avatar
Car: 91 RS
Brian you might be hitting the seals with the retainers and that be causing a leak(s).
(BUMMER)Now that it's together. It sounds like a great combo.
I checked the Vortec's that I ran and they hit the seals at .465. I added .060 shims and offset keepers .050 and got the number up to .515 which gave some clearance to the retainers.
By the way I ran the same cam and rockers that you are using.
Hope this helps!
91 RS 5.0 TBI....LT4 cam....Edelbrock headers....3"Dynomax exhaust....5spd.... 3.08.....Ultimate tbi....afpr...ZR 255-50's...Koni's
Old Nov 21, 2001 | 03:58 PM
irocbsa's Avatar
Hey 91, what part of GA you from.
bsa
Old Nov 21, 2001 | 04:23 PM
If that being my problem is there any way to change the shim and retainers with the heads on the car?
Brian
Old Nov 22, 2001 | 06:01 AM
DM91RS's Avatar
Car: 91 RS
<font face="Verdana, Arial" size="2">Originally posted by irocbsa:
bsa
</font>
Covington
Old Nov 22, 2001 | 06:08 AM
DM91RS's Avatar
Car: 91 RS
<font face="Verdana, Arial" size="2">Originally posted by Brian Felts:
Brian
</font>
Yes Just like you would change the springs out. Remove the old parts add the shims, install springs, install retainers and install the new keepers.
FYI I have found out through some measuring since I have the heads apart that you can also take about .050 off the bottom of the stock Vortec retainers for even more clearance.
I would also upgrade those springs at this time. I beleive that the stockers are living on borrowed time with that lift cam regardless what has been said in other posts.
It probably depends on how hard you run it and how high you take the rpm's.
The .050 offset keepers are a standard Crane part for 7 degrees retainers.
Happy Turkey day.
eightsixseven
Dec 16, 2024 01:50 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
E Rod
Aug 28, 2015 05:17 AM
Bradsaundry
Aug 12, 2015 12:34 AM
