Broken?
Old Oct 29, 2005 | 05:58 PM
87IrocMan's Avatar
Car: 1987 Iroc-Z
Transmission: 5 Speed Manual
Broken?
My heater/ac was working fine up until today when now it will only blow any air at all through the defroster vents. I havent had time to pull the ac unit out yet and i wont have time tomorrow either but I figured maybe it was a common problem like the trip odometer? Any input would help. Thanks
Old Oct 29, 2005 | 06:02 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Sounds like you have lost a vacume line.
If the main vac line from the engine to the panel breaks these things are supposed to default to defrost for safety purposes.
I suggest checking out the line under the hood first before you have the joys of tracking it around inside your dash
Old Oct 29, 2005 | 06:04 PM
87IrocMan's Avatar
Car: 1987 Iroc-Z
ok i will check that out tomorrow. it does sound logical Thanks
Old Oct 29, 2005 | 11:58 PM
kboehringer's Avatar
Car: 1982 - Z28
Engine: 350 / CCC Q-Jet
Transmission: THM-700R4
Axle/Gears: 10 Bolt - 3.73
After you have determined that you have vacuum. If the problem still exists, take a close look at the Duct Control Valve. It is a common problem for the plastic "TIT" to break off (red arrow).
Sincerely,
Kurt
Old Oct 30, 2005 | 05:10 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The control valve itself is also prone to leaking. Either way, stick your ear as close as possible to the HVAC controls and listen for a leak.
JamesC
sheachopper
Jul 31, 2019 11:27 AM
apie2546
Oct 16, 2016 02:24 PM
no green
Jan 9, 2016 09:22 PM
Reid Fleming
Oct 10, 2015 09:56 PM
mfp189
Sep 27, 2015 09:25 AM
