Guide plates w/Comp Cam SA Magnum Roller Rockers?
Old Oct 29, 2005 | 09:54 PM
TKO500's Avatar
Car: 91 B4C, 17 C7 GS, 16 Denali DMax
Engine: LS3, LS3, LML
Axle/Gears: 3.23, 3.42, 3.23
I searched a bunch of old threads about this and found conflicting information. So I wanted to post this up to provide some clarification for myself.
My motor is a 350TPI w/083 heads that have been opened up to 2.02/1.60 with screw in studs and guideplates.
I am installing a set of CompCam Magnum Roller Rockers which are self aligning. The opening for where the pushrod goes through the head is a slotted (rectangular shape w/rounded ends) opening, not a rounded/circle opening.
The pushrods I am using are CompCam specific for the 87-97 w/roller cam. They are hardened for use with guide plates also.
Based on this information do I need to use guideplates?
My thought is no because of the opening in the head being the rectangular shape. I am thinking using the guideplates will ultimately conflict with the movement of the pushrod which could lead to damage somewhere in the drivetrain (bent valve).
Please let me know if I correct with this assumption or not. Thanks!
Old Oct 29, 2005 | 10:01 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Your self-aligning rockers aren't compatible with guide-plates or slotted heads anyway.
Old Oct 29, 2005 | 10:05 PM
TKO500's Avatar
So you are saying I need to get non self aligning rockers and use the guide plates?
Old Oct 29, 2005 | 10:09 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Or get rid of the guideplates somehow.
Old Oct 29, 2005 | 10:10 PM
TKO500's Avatar
Based on the previous response is using my 083 heads w/self aligning rocker arms without the guideplates the way to go?
Old Oct 30, 2005 | 08:08 AM
Karps TA's Avatar
Car: 1985 Trans Am
Axle/Gears: 3.70
Yes. Self aligning = no guide plates
Non self aligning= need guide plates
Old Oct 30, 2005 | 08:11 AM
TKO500's Avatar
Could self aligning rockers used with guide plates cause bent valves due to the interference the guide plates may cause?
Old Oct 30, 2005 | 11:43 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Bent pushrods maybe.
gixxer92
Sep 1, 2015 04:32 PM
camaro71633
Sep 1, 2015 10:24 AM
SLNTSCPE
Aug 22, 2015 09:15 PM
LT1Formula
Aug 20, 2015 09:36 PM
Dialed_In
Aug 20, 2015 01:45 PM
