What Size Belts To Get?
Old Oct 29, 2005 | 10:13 PM
roughskinjrz's Avatar
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
hey, first of thanks in advance.
im running a '72 350, 3970010, and i just purchased a proform pro-66225R electric water pump, moved my alternator to mid motor with the mid brackets from www.alangrovecomponents.com 235R, here is what it says "This mid-mount alternator bracket is designed to work with CSR (and possibly other) electric water pumps. The bracket bolts solid to the head and water pump, and lines the alternator up with a long water pump crank shaft pulley.
", I also got a new march crank pulley 2 grooves MCH-6071, and power steering is in the stock positiion but im bypassing the water pump since there is no pulley the bracket i got for that is from alangrove also its 417L.
now i was wondering what size belts i should get for these, i was making an order with summitracing.com and thought i should get those while im at it, just wanted to ask, because like to get it right the first time!
also what about timing covers? id like to get a chrome one, not sure if they are pretty much all the same? i seen one summit brand for 40$ looks descent.
Old Oct 29, 2005 | 10:14 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Unless someone is running the EXACT same setup as you, the only way I think you're going to find out is to measure.
Old Oct 29, 2005 | 10:18 PM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
yeah i was hoping someone had the same setup, lol
Old Oct 29, 2005 | 10:25 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Chrome is a very bad sealing surface. You can get chrome if you want, sure. If you do, though, sand down the sealing portion of it to ensure you get a good clean sealing surface.
Old Oct 29, 2005 | 10:27 PM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
so go for aluminum if i can?
Old Oct 29, 2005 | 10:29 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
What's wrong with the timing cover you have now?
Old Oct 29, 2005 | 10:45 PM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
nothing, its painted black, just rebuilt the motor, and everything is polished aluminum or red, so i wanted to get a shiny timing cover, its spray painted black by some tool
Nervous2
Oct 8, 2015 10:53 PM
scottmoyer
Sep 20, 2015 11:54 AM
iroczguy86
Sep 13, 2015 02:22 PM
m00n420
Sep 11, 2015 02:39 PM
MORREALE5
Sep 10, 2015 08:58 AM
