low idle & odd start ups.......
Old Nov 22, 2001 | 08:24 PM
z28onTweenkies's Avatar
Car: 1992 Camaro Z28 & 2k3 Cadillac CTS
Engine: LB9
Axle/Gears: 3:43
o.k. this has been bothering me for a while, but each time i start my car in the morning the car starts for a second and immediately dies. then i crank it over and it starts, and it idles at 750 till i tap the gas then the choke operates like it should at about 1300 rpms. after it warms up for a few minutes, i put it in drive and usually its a pretty hard *thrust* into gear. im not sure but its probably bushings somewhere. as im driving for a while and i come to stops, the car idles at a little over 500 rpm, which seems too low. shouldn't it idle and 750? heres some stuff on my car- i set my timing at 0*, ive got new bosch platinums, new bosch wires, accel cap and rotor, msd coil, 180* stat, doesn't burn any oil, and 117,200 on the clock. my choke thermostat is new, and adjusting it right seems to be impossible. all of this and i get about 11 miles to a gallon. any help would be greatly appreciated, sorry for the essay
1987 LG4 Camaro z28
Modifications- Flowmaster 80 series, KN airfilter, high flow cat, 180* stat, edelbrock performer intake manifold, msd blaster coil, ascd big block hood, panasonic cd player, rockford everything else.
Old Nov 22, 2001 | 09:04 PM
Buck268's Avatar
As far as I know, your idle speed (in Drive) should be 450-500 rpm's, thast what mine is set at, and it works fine. It does run highed b4 the engine is fully warmed up...
jklein337
Sep 19, 2018 06:23 PM
apo_bailon15
Mar 28, 2016 05:20 AM
Wade787b
Sep 29, 2015 01:15 PM
perZ
Aug 15, 2015 01:17 PM
mizz0313
Aug 12, 2015 06:45 AM
