Addons to a 305 LG4
Old Nov 21, 2001 | 09:02 PM
black85camaro's Avatar
Car: 85 Camaro
Engine: 350 Carbed
Transmission: Stock 700r4
Addons to a 305 LG4
I have a 305 4bbl. It is running 16.51 stock. Since I have added a K&N air filter, ram air, cut off cat. converter, lightened up the car somewhat.
I was wanting to know if I added a cam what size, what is a good cheap exhaust (cat back or duals), and do I want to use shorty or full size headers on a 85 camaro V8? (I have the 700R4 tranny with 2.73 or 3.08 gears)
I was thinking of this...
Cam Dur- Intake 262 Exhaust 272, .420 lift intake and 442 exhaust lift.
Dynomax shorty headers
Dynomax catback exhaust
GM high rise intake (stock GM off HO I think)
1" carb spacer
Power pullies
home ported and polished
K&N XTream air cleaner lid and cowl induction hood scoop.
Do you think I can get in the low 14's or high 13's on this? What about a good set of gears (both 1/4 mile tims and street drivable).
Thanks guys!!
-Terry-
Old Nov 21, 2001 | 09:18 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Get yourself a Hooker cat-back. There are sound clips of it on the exhaust board in a post. Cost me $200 and had to get it welded on. I don't think you'll reach 13's without doing some head work. I'm not sure which cam to get, but it's a good start. Then get yourself some gears, if you want drivability and 1/4 go with 3:42s. Then get a TC to match your setup. With full exhaust, cam, gears, and TC, I would say 14's would be easy.
And if you haven't done so already do a full tune up.
"Putting any amount of money into a RICE BURNER is like wiping your a$$ with a turd. "
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
3" Hooker CatBack w/Aero Chamber muffler
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat, just switched to 180* b/c of winter coming and going to college in the mts.
3:73 Posi
Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
[This message has been edited by Mark A Shields (edited November 21, 2001).]
Old Nov 22, 2001 | 12:53 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
See sig. I haven't had a chance to run it at the track yet, but it sure feels strong. My cam has .454/.480 lift, 272/284 (216/228 @ .050") duration. Summit lists it as the biggest Crane computer compatible cam with flat tappet lifters. A higher stalling torque converter is the only way to get that much cam moving, and will help even with the cam you suggested.
Porting stock heads will certainly help, but you should also go with 1.94" intake valves. The World 305's already have that size valves, and generally are a step up from ported stock - benefiting themselves from some diegrinder attention.
Not sure what you mean by "HO" intake, but if L69, it's the same as an LG4. If HO crate engine, that's a Vortec model and won't fit 305 heads. Mine came off a ZZ3 crate engine that the guy converted to TPI. I'm not sure how much, if any, the carb spacer will help you.
Make sure your exhaust is at least 2.5" downpipes and 3" y-pipe at the cat, 3" cat and catback. Anything smaller will likely choke it.
Stock with an open element air cleaner, I ran 16.85's at 5800' elevation (air density was more like 8500'). Without a doubt it is much, much stronger now. Desktop Dyno estimates peak HP at 360 @ 6000 RPM. Drag simulator has that in the low 15's/high 14's at this altitude (3.73's would give it almost 3 tenths). That should be 13's at lower altitudes. But, the proof is at the track, and that will have to wait until spring.
I have also noticed an enhanced capacity to pull gasoline out of the gas tank...
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4, 2300 stall TC. Ported World 305 heads, Crane PowerMax 2050 cam. ZZ4 intake, oil pump, pan & baffle. Accel HEI SuperCoil & module. Hooker 2055 headers, 3" Catco cat & 3" catback w/dual-opposite Flowmaster 80. 2.93 limited slip. Spohn SFCs waiting to be installed. AMSOIL syn lubes bumper-to-bumper. Daily year-round driver. Best ET, speed TBD...
57 Bel Air, my 1st car. '66 396, 9.7:1 forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 700 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
Old Nov 22, 2001 | 05:03 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
This exact topic gets re-posted a couple of times a day. This is what the search engine on the site is for.
Here's yesterday's version of it.
https://www.thirdgen.org/messgboard/...ML/015773.html
ICON Motorsports
Old Nov 23, 2001 | 03:27 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Change the carb, Edelbrock 1406,
Here is my old setup,
Here is a video of me racing an 99 LS1 Trans Am, I keep up for a little while,
http://www.donpagevideo.com/video/Manny_vs_Charles.mpg
WS6 Trans Am.
View My Ride @ thirdgen.org
Old Nov 23, 2001 | 03:58 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Zepher, what color is that engine? Looks great!
SSC
Old Nov 23, 2001 | 11:03 PM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
I recognize that color... looks like Pontiac Big Block color to me...at least I think so.
-1983 L69 Camaro Z28 305 H.O. (Bored .030 over,Teflon oil seals,Melling H.V. oil pump,Hyperetic pistons,chrome-moly rings,T-tops, 3:73 Open rear, BW T-5, Rebuilt E4ME 4 Barrel, Duel Snorkle Air Cleaner w/K&N Filter , Rhino Clutch, Crane 2040 Compu-cam, LS1 valve springs, porting, PST front end kit. Now for paint, interior, etc...etc.... Also:
2000 S10 4.3L 4WD LS
1995 Ford Thunderchicken, 4.6 V-8
db057
Apr 28, 2019 07:45 AM
383cam
Sep 9, 2015 06:01 AM
buffaloman
Camaros Wanted
Sep 7, 2015 09:46 AM
rsrookie
Sep 5, 2015 07:08 PM
Formula_88AE
Sep 3, 2015 01:47 PM
