will this rust??
Old Nov 2, 2005 | 08:30 AM
phealinphine69's Avatar
will this rust??
i just got my pistons delivered to me and i was wondering if i should spray some WD-40 on em to keep from rusting. it wont be a real long time til i get it all put together, but i am in college so it is going a little slow right now. they are just reg. hyper pistons.
this just crossed my mind. i have my blocked sprayed down with a lil WD-40 also, is it ok to leave remains of WD-40 in the cylinder bores when i go to put the engine together or am i having to completely remove all the remains before i get the lower end together>?
if anyones curious: 406, speed pro flattops, eagle sirlightweights, stock crank, i need cam recomendations to go with some afr/s 210!!! anybody want to help with this one?
Old Nov 2, 2005 | 09:46 AM
Pistons are aluminum. They won't rust even without WD-40.
Leaving the WD-40 on the block won't bother anything.
When you build the motor, use 2-stroke oil as your build lube on the rings.
I'd suggest a Comp XE274H cam, with 1.6 roller rockers.
Old Nov 2, 2005 | 10:09 AM
vic_V8's Avatar
Car: RS
Transmission: 4L60
the rings aren't on them yet are they?
Old Nov 2, 2005 | 11:52 AM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
ya, the pistons wo't rust, but the rings will.
Old Nov 2, 2005 | 12:31 PM
no rings yet, i posted this to early in the morning i was thinking that the pistons were 5140 steel, like the Sirlightweight rods that im ordering, i knew they were aluminum. i have the stock 400 rods sitting in the garage and they are starting to rust, but they've been out in the rain and shine for a lil while. i'll keeping all parts indoors til i ready for the build.
Old Nov 2, 2005 | 07:10 PM
zimmchile7's Avatar
Car: 1985 Trans Am
Engine: 383 Stroker
wd-40 everything except what you want to pant. It'll all burn off anyway. Aluminum will corrode but not with rust. It's more like white chalk. It'll take a long time to do so though. A little prevention...
Old Nov 3, 2005 | 02:24 AM
R1UK's Avatar
Car: Was 3rd Gen now MustangGT
Engine: 302
Axle/Gears: 3:73:1
Cant go wrong with wd40, it cures everything, and will keep corrosion at bay.
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Fireslash
Apr 11, 2016 06:43 PM
FueledSoul
Sep 30, 2015 09:18 PM
tcflint
Sep 27, 2015 05:58 PM
