Help!!! Antifreeze in the Pass footwell
Old Oct 29, 2005 | 11:12 PM
Loudmouth's Avatar
Car: 87 camaro z28
Engine: 2.8l V-6
Transmission: TH-700R4
I put a full tank of antifreeze in my 87 camaro friday night i get up saturday morning and the windshield has frost so i turn on the defroster and go to work get to work and park and everything is cool work for 7 hrs come back and get in and reach over for one of my cds look down and see a green liquid in the footwell dabed my finger in it and smelt it and it turned out to be antifreeze. what could possiblely be the problem and how can i fix it
Old Oct 29, 2005 | 11:17 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Heater Core.
Old Oct 29, 2005 | 11:25 PM
91RS3RDGEN's Avatar
Car: 90 Full size Jimmy 4" lift
Engine: 350 TBI
Axle/Gears: 12 bolt rear 14 bolt front 3.73s
Definitley your heater core.I don't know what it takes to change on on a third gen I have'nt had to do it yet but i know on a mustang its a PITA.
Old Oct 29, 2005 | 11:29 PM
chevymec's Avatar
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
definatlly sounds like the heater core. I dont think its too bad to do. Espically if somebody has done it once and not put all the bolts back in !!
Old Oct 30, 2005 | 04:44 AM
R1UK's Avatar
Car: Was 3rd Gen now MustangGT
Engine: 302
Axle/Gears: 3:73:1
You can always do a temp fix, take off the 2 heater pipes at the bulkhead\firewall and join them together with a bit of copper tube the correct diameter. [or any metal tube].
You can still use the car, just no heater, but it means your not off the road.
Old Oct 30, 2005 | 05:07 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Do a search and you should find all the info you're looking for.
JamesC
Old Oct 30, 2005 | 10:21 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Also could be the hoses going into the core leaking.
Another member here did a core change and couldnt find out where a/f was still coming from and it was the hoses. Dont ask me how but i guess it can drip through the firewall and get on the floor.
Old Oct 31, 2005 | 10:25 PM
formula forever's Avatar
Car: 91 formula
Engine: 350 tuned port. bolt ons
yep i was that other member. it easy the only really hard part is geting the old hoses of the heater core. just cut them off with a razor blade or knife. don.t replace the heater core without putting new hoses on it
Old Nov 2, 2005 | 02:19 AM
irocbarry's Avatar
Car: 85 IROC
Engine: L-69 305
Transmission: T-5 manual
R1UK
that probably aint gonna work
there two different size hoses
i know this cause i just checked the size on one when i baught hose, caused another hitched ride to b to b
Old Nov 2, 2005 | 03:47 AM
R1UK's Avatar
Engine: 302
Axle/Gears: 3:73:1
It will trust me, the diameter is slightly different, but some worm drive clips will sqeeze it tight enough, i know coz ive had to do it.
Old Nov 2, 2005 | 03:48 AM
irocbarry's Avatar
Car: 85 IROC
Engine: L-69 305
ya i guess i fyou squeezed the hose hard enough it would work, deff not optimal
Old Nov 2, 2005 | 03:07 PM
misterrick's Avatar
Car: 92 RS
Engine: 3.1
sorry to say everyone here is right its the heater core. Ive done one in a 79 T/A and some older camaros and its takes some time but its not too bad. Good Luck
Old Nov 2, 2005 | 04:20 PM
Angelis83LT's Avatar
Car: '83 Berli, '84 Berli, '84 Z28 HO
Engine: L69, LG4, L69
Transmission: TH700-R4, TH700-R4, T-5
Axle/Gears: 3.08, 3.08, 3.73 Posi
Yea that is the heater core, and it is a PITA. I just got done doing mine. the biggest thing is the top screw up there is a real PITA. not much room for any decent sized tool to do anything and it is all one handed. I finally got fed up and onbolted my dash from the firewall, undid the top of the console (all this took like 15 minutes) and then pulled the dash up and out and gave me great access to the heater core and tons of room. If I would have done it that way to begin with rathe than try to play around with the top screw, I would have had the thing out and in , in about an hour and a half to 2 hours. hooked up and running.
Old Nov 2, 2005 | 06:59 PM
zimmchile7's Avatar
Car: 1985 Trans Am
Engine: 383 Stroker
If you get a haynes book from any local hardware store it will tell you step-by-step with pics how to change it out. This way is actually the easiest. I was intimidated when I first read it but it is actually not that bad. Trying to figure it out yourself will just lead you to doing it the same way the book tells you to. B.T.W it is most likely you heater core.
z
Old Nov 2, 2005 | 07:00 PM
zimmchile7's Avatar
Car: 1985 Trans Am
Engine: 383 Stroker
Didn't mean hardware store. Mean't auto parts store. Sorry too many beers
Old Nov 2, 2005 | 10:26 PM
88GTA3555SPD's Avatar
Car: 88GTA
Engine: 383
Transmission: t5 junk
i done more than couple heater cores in third gens...unbolt the dashpad, unbolt main dash frame from pillar etc.. put something between pillar and dash to hold it back a bit like a 2x4. unscrew cover from heater case...top screw is very painstaking i used a mini 7mm wrench.
ive only done them in firebirds n t/a's, in the camaros u might need to move the console/radio pod back or take it off
Old Nov 3, 2005 | 05:11 AM
JamesC's Avatar
The following link may be helpful:
https://www.thirdgen.org/techbb2/sho...hreadid=210395
JamesC
darwinprice
17
Oct 11, 2015 11:51 PM
racereese
Oct 3, 2015 03:46 PM
