what the #@$%? knocking?
Old Nov 24, 2001 | 12:06 AM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
well while the engine is idiling i can hear a faint sound and sounds alot like it's knocking. the knocking sounds like it's coming from the bottom end of the engine and is more prominent while the engine is cold. my theories are loose convertor bolts or a worn front pump bushing(on trans). i haven't had a chance to check out my theories yet, but will do so tomorrow. i hope that's it's not the engine. the vehicle/engine only has 88K original miles. any ideas? thanks for any replys.
86',88',89' IROC-Z, 350 TPI, 700-R4
94' Formula, LT1, 6spd
Old Nov 24, 2001 | 06:36 PM
Z's r Best's Avatar
Car: '86 IROC, black and sharp
Engine: 305 tpi, bone stock
Axle/Gears: 3.42 pos w/rear db
Hey, I'm really curious about what you find out. I've got one 86 IROC that runs great, but I just bought another 86 IROC that has a knocking/thumping noise. The guy I bought it from said he was told in was a main bearing (freshly rebuilt 350 still in it's break in period). It has great oil pressure when idling cold. I was also going to check the torque converter bolts and the harmonic balancer when I get the time. Let us know what you find. Thanks.
Z's r Best
Old Nov 24, 2001 | 06:52 PM
SoCo80p's Avatar
a trans problem with the converter bolts will make un unsteady clunking noise at idle. if its a constant sound like you said from the bottom of the engine and louded at startup thats forsure a bearing going south.
Old Nov 24, 2001 | 09:21 PM
Car: 1988 IROC-Z
Well it only does it at idle and does not get any louder at engine speed increases so i'm just hoping for loose bolts or anything other than the engine. i hope it's nothing major. the 88' is my favorite.
RedLeader289
May 28, 2019 01:47 PM
bigjay89gta
Oct 15, 2015 08:04 AM
efiguy
Sep 27, 2015 01:30 PM
spartanreaper
Sep 25, 2015 07:22 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
