What gear to get
Old Nov 3, 2005 | 08:35 PM
Duke901's Avatar
Car: 89 Formula
What gear to get
I have a 438 big block 11.5 compression with a 595 lift cam, 2800 stall and a 700r4. I want to get 4:10 but a friend also mentioned 456. What do you guys recommend. Thank you
Old Nov 3, 2005 | 08:39 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
4.10 is pretty steep and the 700r4s have fairly steep first gears too, i would say go with something like 3.73s if you feel it doesnt have enough coming out of the hole.
What do you plan on doing with this car? strip or street/highway?
Old Nov 3, 2005 | 08:45 PM
Duke901's Avatar
Car: 89 Formula
Mostly strip
Old Nov 3, 2005 | 09:01 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
What are you running at the track?
60' times?
ET?
MPH?
RPM at end of track?
I think if you go with any 4.xx you will find yourself reading the newspaper about 1/2 way down the track unless that engine pulls to 8k RPM
gta892000
Aug 11, 2019 11:16 AM
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
