Converting from TBI to TPI.
Old Nov 4, 2005 | 11:32 AM
oifish's Avatar
Car: 1992 Camaro Z28
Engine: 5.7 TPI L98
This is probably a dumb question, but if I wanted to convert from TBI to TPI, I would have to do an engine swap right? Or is there another way? Thanks.
Old Nov 4, 2005 | 11:42 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
just change the induction setup...
Old Nov 4, 2005 | 12:11 PM
Codename 47's Avatar
Car: 1986 Camaro Z28
Engine: 400
Axle/Gears: 10 bolt Posi 3.73
Nope, all you have to do is remove your TBI unit (looks like a carburator), and the thing it sits on (the intake). Then you replace it with equivalent but better TPI parts . You also have to mess around with some computer stuff though (I think). THere was a full TPI 350 for sale in the classifieds at one point, you should check that out, I think it's 900 bucks. I'd just go with the 350 right away, you can find them for about 1000 bucks.
-Greg
Old Nov 4, 2005 | 12:18 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
Yes you would need all the sensors and wiring harness, computer and a new fuel pump. In the end you could probably pick up a turn key TPI 350 for the same price as converting the 305.
Old Nov 4, 2005 | 04:04 PM
Rally Smith's Avatar
Car: 91 RS
Engine: 305 TBI
Axle/Gears: Factory 2.73 (unfortunately)
Why would you want to give yourself such a big head ache?
If you question the ability of the TBI setup you should do some checking. They are a very capable mode of induction. Check out the following links before you swap anything.
http://www.goingfaster.com/spo/modthel03.html
http://chevyhiperformance.com/techar..._0409_mission/
Old Nov 4, 2005 | 05:46 PM
oifish's Avatar
Engine: 5.7 TPI L98
Yea, I figured it be a much better idea to get the 350 TPI. Thanks for clearing that up.
1992 Trans Am
May 10, 2023 07:19 PM
MustangBeater20
Oct 29, 2022 09:20 PM
Dwayne614
Sep 28, 2015 08:33 AM
z28addict8490
Sep 5, 2015 03:56 PM
jer4251
Sep 1, 2015 09:04 AM
