Loss of Power
Car: 1992 Camaro Z28
Engine: 5.7 LT1
Transmission: 4L60
Axle/Gears: 3.23's
Loss of Power
Ok I just had a good friend of mine who is also a proffesional mechanic, replace the intake manifold gasket , and EGR solenoid and solenoid wiring harness. And I asked him to advance the timing a few degrees. He says that he advanced it 2 degrees. But now my car doesnt seem to have that same speed. Its still quick, but it wont spin the tires from a stop anymore, and it just doenst move like it used to. Is it possible that the advance is too much.
Car: 91 RS
Engine: 305 Tbi (L03)
It is possible that its advanced to far and causing the knock sensor to retard the timing, but 2 degrees usually wont do that. Did he unplug the est wire while setting timing? Its very difficult to get an accurate reading with it pluged in.
Car: '88 IROC-Z medium orange metallic
Did he plug the EST wire back in?
Could be too much timing now and you're getting knock, and the sensor is pulling out timing.
Or you could have a vacuum leak now.
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Yeah any of those...basically check over everything he touched. Does your brake pedal feel any different, any fading or a little harder than usual? Major vacuum leaks can be felt through the brakes sometimes. I'd definitely check into the timing...sounds like for some reason it's being retarded not advanced. Does the car seem to start up real quick and idle maybe 50 or 100 rpms below what it used to?
Engine: 5.7 LT1
Transmission: 4L60
Axle/Gears: 3.23's
Yea its starts up faster , and idles lower, and on top of all of that , I dont **** for oil pressure ,it used to be around 30-50 , now at idle its at 0 and it barely ever gets to 30.
Car: 89 jaguar xjs convertable
Engine: 89 L98 5.7 TPI
Axle/Gears: 3.23 dana 44
Is the distributer in right??? No oil pressure means the pump isn't connected to the dizz, I'm thinkin! Sorry my bad, you do have oil pressure.
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
if it starts faster and idles lower, I think that's a sign the timing was retarted, rather then advanced.
Engine: 5.7 LT1
Transmission: 4L60
Axle/Gears: 3.23's
Really, but I hope that he didnt screw up soo bad that he retarded it instead of advancing it, oh well I guess Im gonna have to have him look at it monday. Another thing the exhaust is louder at idle , and it sounds more lopey, but he did clean out some gunk when he replaced the intake manifold gaske, so I dunno whats going on. Go messing with the timing make the exhaust sound different, or could the lower idle just make it sound differen??
Sounds like your timing is definitely retarded, you got all the tell-tale signs. Figure out that oil pressure though...verify with a manual gauge not electric if possible. Nothing he did should have affected your oil pressure. Does the motor knock at idle esp when cold...or is there a lot of valvetrain clatter? Oil pressure that low, if thats correct, will hurt the motor real good real fast, esp if you rev it out at all
Engine: 5.7 LT1
Transmission: 4L60
Axle/Gears: 3.23's
Ya I didnt think anything he did could have affected the oil pressure. All I know is it had good oil pressure before I brought it in. So hes going to have to find out what happened. But I also just thought that possibly it had more advance before he worked on it. I've never changed the timing before so its possible it had more advance and that when he changed it. It's now lower.
I hope he knows about the EST connector....
Car: 77 K20 80 K2500 93 C2500 94 K1500
Engine: 350 350 454 350
Transmission: 350 465 80E 60E
Axle/Gears: 4.10 3.73 5.13 3.73
Originally posted by Nixon1
But if he RETARDED it from where it was, wouldn't he have told you that, or asked you first?
Originally posted by BackInBlack86
unless he didnt know the difference. unfortunately, any monkey with a toolbox can get a job working on cars professionally, all you need is a good line of BS.
Engine: 5.7 LT1
Transmission: 4L60
Axle/Gears: 3.23's
OK so I brought it back to him and we re-did the timing. He forgot to disconnect the EST and didnt tighten the distrubtor hold down bolt and it had dropped the timing 6*!!!!!!. So we brought it back to base and then advaced it 10*. The engine is perfect right now , and after giving it a run on the *** dyno its alot faster than it was before I had any work done to it. As for the oil pressure were putting a mechanical gauge on it tommorrow. But we both think its the sending unit because , at idle it shows 0 pressure and there is no noise or chatter coming from the valvetrain and if there was no oil going in there it would be very noisy.
...You advanced it 10 degrees OVER base? You sure that's a good idea?
Engine: 5.7 LT1
Transmission: 4L60
Axle/Gears: 3.23's
No OOPS I meant over what it was. It had been brought down 6* and we brought it up to base and then 4* over. A total of 10*, haha ya 10* over base would be alittle much.
theshackle
Sep 17, 2020 08:26 AM
sailtexas186548
Aug 24, 2015 10:11 PM
