Rough Idle
Old Nov 24, 2001 | 11:05 PM
SgtSkip's Avatar
Rough Idle
This seems too simple but I need second opinions. I just replaced my timing chain and now I have a rough idle. I set the timing but that didn't help. It almost feels like a missing cylinder. In the past I could jumper the A and B terminals on the computer plug (technical term) and the idle would drop a bit. Now it does nothing. I do get a little advance when the enging is reved but only about 3 degrees. I don't think it matters in this case but I've never been able to get in to "field service" mode before either. Reading codes is no problem. Any ideas??
85T/A 305/QJ work in progress.
Old Nov 25, 2001 | 09:11 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Check for vacuum leaks or maybe a burnt/fouled plug wire.
I can die now knowing I have fulfilled a dream. 6th row from courtside.
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
3" Hooker CatBack w/Aero Chamber muffler
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat, just switched to 180* b/c of winter coming and going to college in the mts.
3:73 Posi
Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
Old Nov 25, 2001 | 09:22 AM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
<font face="Verdana, Arial" size="2">Originally posted by SgtSkip:
</font>
hopefully you didn't put the chain in one tooth off.
Old Nov 25, 2001 | 12:14 PM
SgtSkip's Avatar
It shouldn't be one tooth off since the timing is right on. I thought I might have at first since I accidentally moved the crank a touch when I was pulling the sproket off.
Old Nov 25, 2001 | 01:56 PM
mrr23's Avatar
Engine: 360 HSR
It shouldn't be one tooth off since the timing is right on. I thought I might have at first since I accidentally moved the crank a touch when I was pulling the sproket off.</font>
ignition timing and cam/crank timing are two different things. having the cam one tooth off means the valves are opening and closing at the wrong time. ignition timing is when the spark gets to the cylinder.
Old Nov 25, 2001 | 09:01 PM
SgtSkip's Avatar
Ahhhh, I didn't know that. I sure hope I didn't do that. It's running good enough to get by for now so I won't tear back in to it to check.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
89fast5oh
Sep 8, 2015 09:55 AM
IROCtometal
Sep 2, 2015 02:01 PM
