twisted wedge heads
Old Nov 24, 2001 | 03:42 AM
ausrs's Avatar
twisted wedge heads
does anyone here no anything about the 23 degress twisted wedge heads ??i have been waiting for over 12 months for a set of l 98 heads to arrive BUT no matter how many times i am promised they never arrive
today i was talking to a guy who has a set of thjese for sale and would like to here from anyone who has used them NOT just from their tech site
thanks
Old Nov 24, 2001 | 07:38 AM
Jza's Avatar
Jza
I've not used them personally, but I pulled a set from another Camaro once and noticed that they had to grind their nice Crane roller rockers to fit in between the offset valves at the ends.
Old Nov 24, 2001 | 06:40 PM
Guest
Guest
Posts: n/a
I havent used them either, but I think they are being discontinued. Summit only shows 1 part number, and the trick flow website doesnt even have them listed for SBC's anymore.
Old Nov 24, 2001 | 09:47 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
<font face="Verdana, Arial" size="2">Originally posted by madmax:
I havent used them either, but I think they are being discontinued. Summit only shows 1 part number, and the trick flow website doesnt even have them listed for SBC's anymore.</font>
The 23° heads are here: http://www.trickflow.com/product/prh...ture_index.htm
86 Camaro Sport
LT1 Induction
383 Speed-O-Motive Crate Engine, Raptor 700R4 Tranmission, Trick Flow Twisted Wedge G2's, 58mm Accel TB, 3.73 Auburn Pro, SLP Cold Air Induction and Headers, Hooker Cat-back, Serpentine Belt Setup, Dual IROC Fans, Jamex springs, 16" IROC Rims, 36mm/24mm Sway Bars, Global West Steering Brace. Hotchkis Rear LCA's,Panhard Bar and SFC's.
My Camaro Project
Moderator at SE ThirdGen
Old Nov 25, 2001 | 12:05 PM
Guest
Guest
Posts: n/a
Only one problem John, those aren't the 'twisted wedge' heads.
Old Nov 25, 2001 | 12:13 PM
irocbsa's Avatar
Aus, I have a pair on my car and they're OK. The screwed up valve placement necessitates cutting the braces out of your valve covers (15 minutes with a rotary cutting tool) and some rockers have a fit. Mine cleared fine. TFS also recommends that you don't use rockers with a higher ratio than 1.5. So that kinda sucks. For my next buildup, I'm staying away from them.
bsa
Old Nov 26, 2001 | 11:53 AM
Damon's Avatar
Irocbsa hit it on the head. To make matters worse, you HAVE TO buy custom length pushrods, so figure spending another $150 over the cost of the heads themselves.
Yes, I really installed a set of these myself on my car (brother's car, actuall) so I speak from personal expereince.
Next time out I think we'll use a set of their more traditional 23* heads- fewer headaches and probably almost as good as the Twisted Wedge heads.
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
92projectcamaro
Jan 18, 2016 08:00 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
z28guy134
Sep 1, 2015 11:50 PM
