3 Questions......
Old Nov 6, 2005 | 01:20 PM
BOSS 357's Avatar
Car: 89RS,89TBI FB, 91Z28, 89TPI FORMULA
Engine: 357 SBC TPI
Transmission: World Class T-5 (for now)
Axle/Gears: Strange 12-bolt 3.73
3 Questions......
1) I'm swapping out my 2.77 gear and going w/ a 3.73, do I need to recalibrate my speedometer?
2) I usually roll my car up onto ramps when I work under there, now I need to get the whole car up on jackstands and i'm wondering..can I put the jack under the differential to jack the rear without hurting anything? Also can I use that beefy cross member under the engine to jack the front without hurting anything?
3) I recently had an Edelbrok 67gph fuel pump installed on my car. When the tank has more than 1/4 in it, it sounds like the pump will "humm" intermittantly for 3-4 seconds every 20-25 minutes or so. If I open the gas cap and release the pressure, it doesn't seem to happen again until I run the car. Any ideas of what this could be? (obviously I think it's the pump since it's the only thing new and electrial back there, but I'd prefer a more seasoned opinion)
Thanks to all who respond....
Eric
Old Nov 6, 2005 | 01:29 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
1. any gear change will need a speedo calibration
2. i use the diff to jack up the rear on mine, no problems there. As for the front im not sure as i usually drive it up on blocks.
3. sounds like your getting a vapor lock if your tank is getting pressure or vacume. possible plugged vent, try a venting gas cap if you dont want to chase down lines.
Old Nov 6, 2005 | 01:46 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
2) yes, the k-member is a perfect jack point at the front.
3) I agree, vented gas cap.
Old Nov 6, 2005 | 04:02 PM
BOSS 357's Avatar
Engine: 357 SBC TPI
Thanks Sonix & 84Z. If I may ask a follow up question, can I set the rear down on the stands using the axle tube and where up front are good points for the stands?
Old Nov 6, 2005 | 04:23 PM
Scheister's Avatar
Car: 85 IROC
yeah you can put jack stands under the axle tubes
Old Nov 6, 2005 | 08:13 PM
Sonix's Avatar
Car: 1982 Trans-Am
my rear sway bar is in the way, so I couldn't use the axle tubes.
I used the LCA's, or the brackets on the axle for the LCA.
My car is on the rear frame rail area right now..
I use the front control arm, right below the coil spring (the pocket), for jack stands in the front.
Old Nov 6, 2005 | 08:22 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Can also use the pivot point where the A-arms attach to that big front crossmember for stands. In the rear you can also use the frame itself just in front of the LCA attachments. Many times, when doing rear end work, you can't jackstand the LCA's, as they need to move or get detached. If your changing out the rear, you'll need to jack in front of them, not on them.
Old Nov 6, 2005 | 09:42 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Old Nov 6, 2005 | 10:27 PM
BOSS 357's Avatar
Engine: 357 SBC TPI
Thank you all for the responses. Man..nothing beats a PICTURE! F-BIRD, that rocks! I don't really care for lying under a 3400lb car so that's why I wanted to ask all you pros out there. Thanks again fellas.
Now I just need to buy a creeper....
Eric
Old Nov 7, 2005 | 03:44 AM
firebird45331's Avatar
Car: 86 Firebird, 2002 Monte Carlo, 91 v
one thing about about using the front k member as a jack point, make sure you're on level ground. I jacked there on my c1500 the truck wasn't level and the weight shifted and it fell about the time I putting my jack stands under it. I nearly pissed myself.
Old Nov 9, 2005 | 03:20 AM
QuickStyle's Avatar
Car: 91 Z28
Engine: 383 SuperRam
Transmission: ProBuilt 700r4
Axle/Gears: G92 3.23
i used to think that too... till it slipped off and landed on my centerlink driving it into my oil pan, and had to replace my oil pan, gasket, and centerlink.
