2.8 wont start
Old Nov 7, 2005 | 04:29 PM
fearfactory17's Avatar
Car: 1989 Pontiac Firebird
Engine: 2.8L V6
Transmission: auto
2.8 wont start
i recently did a valve job on my firebird and im having no luck starting the car, it cranks but thats about it, sometimes ill hear backfiring while its trying to start. but im pretty sure i did all of my timing right. i put the distributor in TDC on the compression stroke of the number one cylinder and checked my spark plug gaps and my wires. ive tried turning the distributor while somebody tries to start it and still nothing. could it be my fuel injector wires? maybe they got mixed up or something. i also notice gas sometimes is found on the top of the fuel rail after trying to start it for a little bit? any suggestions?
Old Nov 7, 2005 | 05:01 PM
firebird45331's Avatar
Car: 86 Firebird, 2002 Monte Carlo, 91 v
i'd find that gas leak first. I bet your distributor is 180 out possibly. Had the same issue after doing a tear down on my motor, come to find out it was just an oversight on my part. I wired the ignition wires in counter clockwise, like a mustang. I'd definitely find where that gas is coming from before you do anything else though. One good spark or backfire and it's bye bye birdy
Old Nov 7, 2005 | 05:32 PM
Engine: 2.8L V6
Transmission: auto
i think maybe the gas is just because im flooding it?
Old Nov 7, 2005 | 07:22 PM
don't know there, I've never flooded a fuel injected motor, can it be done?
Old Nov 7, 2005 | 07:27 PM
Engine: 2.8L V6
Transmission: auto
i have no clue, thats why it never hurts to ask
Old Nov 7, 2005 | 10:08 PM
PhLaXuS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: 2.73 Posi w/Disc
I've the understanding that certain GM ECM's can be tricked into a "flooded" mode if you try cranking with the throttle wide open. In this mode, the ECM will command only a very small (or maybe none at all for a time) amount of fuel from the injectors. If you think you're flooding out, give it a shot.
Old Nov 8, 2005 | 09:42 AM
Engine: 2.8L V6
Transmission: auto
anybody got a diagnostic chord that plugs into your computer, i got all the software i just need that chord. then itll be extrememly easy to find out whats wrong
Cleotiz
Jan 6, 2018 08:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
E Rod
Aug 28, 2015 05:17 AM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
86Base
Aug 8, 2015 01:34 PM
