Problem with Oil leak
Old Nov 7, 2005 | 05:47 PM
TransAm90GTA's Avatar
Car: 1990 Trans Am Gta
Engine: 350 5.7
I just put my new engine in and went to start the engine and oil started to come out of this hole. It looks like a bolt hole but im wondering if something is supposed to be mounted there. Its on the right back of the block looking at it so if anyone could look for me and tell me what goes there it would really help thanks
Old Nov 7, 2005 | 07:19 PM
thebigwelsh's Avatar
Car: 88 firebird under construction
Engine: 350 with trick flow everything
Transmission: th350
Re: Problem with Oil leak
Dude, thats the port for your oil pressure sending unit. Stick one in there, or put in a plug and fire er up.
Old Nov 7, 2005 | 09:12 PM
Engine: 350 5.7
Thanks man
Old Nov 7, 2005 | 09:16 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Some people are unaware their are 2 locations for the sending unit, One up by the dizzy and the one down by the filter
Just plug whichever one your not going to use and youll be good to go!
Old Nov 23, 2005 | 07:33 AM
dennisbernal91z's Avatar
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
Is it possible to not have one down by the filter? My block doesn't seem to have one. I guess I can allways add oil (new motor that the guy up above built for me ((thebigwelsh)) ) and prime the motor and see if any spills out.
thebigwelsh, you have a PM
Old Nov 23, 2005 | 11:56 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Yes it's possible. Either location works. Double check to make sure there isnt a pipe plug in there somewhere.
Infested
May 22, 2018 11:56 PM
Navy8125
Aug 21, 2015 09:32 AM
355sbcTPI
Aug 19, 2015 04:38 PM
drathaar907
Aug 6, 2015 04:20 PM
