why is it tapping or knocking?
Old Nov 8, 2005 | 04:19 AM
killer89ta's Avatar
Car: 89 trans am
Engine: lB9w/ tbi
Transmission: t-56
i knew my car had an exhuast leak but now there is another noise....it sounds like a loud tapping....it isn't always there but in higher rpms or sometime idle it is there....it comes and goes...at first i thought i threw a rod....then maybe it was my lifters which i think it might be but i'm not too sure...i don't wanna replace one thing and then it end up being something else....so any ideas? or comments? if i can't get any answers i'm not taking any risks and replaceing the engine before i waste more money and blow the dam thing.
Old Nov 8, 2005 | 11:10 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Check/set the valve lash recently?
Old Nov 8, 2005 | 08:13 PM
cheese_kake's Avatar
Car: 1992 Camaro Z28
Engine: 5.7 LT1
Transmission: 4L60
Axle/Gears: 3.23's
What is a valve lash set ??
Old Nov 8, 2005 | 10:15 PM
HalfInchWrench's Avatar
Car: 85Z28 87GTA 91GTA 98SS
Engine: SBC, LS-x
Transmission: T-5, 700-R4, T-56
You have it backwards, it's setting the valve lash.
Try that in a search. You will find your answer.
Old Nov 8, 2005 | 10:24 PM
Engine: SBC, LS-x
Re: why is it tapping or knocking?
When is the last time you "adjusted" the lifters?
Jacked the engine up lately, sorta like a bent oil pan?
Get yourself one of those automotive stethoscope things and pinpoint the noise.
RedLeader289
May 28, 2019 01:47 PM
bigjay89gta
Oct 15, 2015 08:04 AM
efiguy
Sep 27, 2015 01:30 PM
Ragtop Man
Sep 12, 2015 12:23 AM
dimented24x7
Sep 6, 2015 03:51 PM
