Idle Problems
Car: 86 IROC
Idle Problems
My engine idles rough all of the time. It also doesn't have any power util about 2200 rpm. I tried cleaning the throttle body, but that didn't seem to help any. When I disconnect the small vacume line from the bottom of the tb, it idles fine, but at a higher rpm. Any suggustions?
86 iroc, tpi, auto, compucam, headers, pace-setter cat-back, stageII chip, afpr, air foil, filters, maf screens removed, gutted air cleaner box, 160* stat.
Car: 86 IROC
The most recent things I have done is gutted the airbox and remove the maf screens, but ir ran fine after that. It started doing this about two months ago and gradually got worse.
Car: 86 IROC
It comes from the fuel vapor canister, and goes back to the egr. Will it matter if I just disconnect it from the tb?
Car: 86 IROC
Help Please!!!! This is driving me nuts!!
Could this be a problem with the fuel vapor canister?
[This message has been edited by 86iroctpi (edited November 27, 2001).]
Car: 86 IROC
Could the egr solenoid have any thing to do with this?
