best way to keep my car running cool?
Old Nov 25, 2001 | 09:42 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
dual fans..if so what kind and where can i get them
should i get a new switch?
could i get something that is a manual switch?
84TA T-tops L-69 305HO TH-700R4 stock 190hp and 240 ft-lbs.
new best E.T. (dont laugh) 15.986 @84.93mph
old best E.T 15.997@86.04
http://www.geocities.com/K_towngangsta
Mods-
K&N Air filter
Hooker Cat-Back
Old Nov 25, 2001 | 09:59 PM
Don Christensen's Avatar
Car: 1989 Formula - Red
Transmission: 700 R4
Axle/Gears: 3.73 Posi
First make sure the air dam is good.
I put new air dams on both of our Birds, and they both now run at 185 degrees.
Old Nov 25, 2001 | 11:00 PM
DANIELEK's Avatar
Car: Red Rooster
Transmission: M5
I replaced my stock 195 degree thermostat with the 180 degree High Flow and made a manual fan switch.
This setup works great for me. My car never gets hot. I can always control the coolant temp by using the manual switch or I can let the ECM control it.
89Iroc, 305 TPI, WC T5, 3.08 Posi, Flowtech Headers, 3 inch over the axle, Flowmaster 80, Aluminium Driveshaft, Ported Plenum, Air Foil, K&N, AFPR, Smog/AC Delete, 3300lbs, All free mods
Old Nov 26, 2001 | 11:43 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
how do you make the manual switch?
Old Nov 27, 2001 | 12:10 AM
rezinn's Avatar
All you need is a toggle switch and about 12 feet of wire. Wire the switch inside your car to a ground, then to the wire from the sensor going into your passenger side head. When grounded your fans should turn on. I drilled a hole and threaded a switch through my fuse box to run this way.
Old Nov 27, 2001 | 09:11 AM
85transamtpi's Avatar
Sounds like what I did. Definetly check the air dam. As stupid as it seems, without it you'll never solve your cooling problem.
Old Nov 27, 2001 | 11:28 AM
DAHULK2000's Avatar
Ok guys, i had posted this question a while back, but i still didn't solve my problem. My fan ain't starting. I turn on my ac, it doesn't start, so i replaced the relay. I tried it again, it still doesn't start. I know my fan motor works cuz we checked it out in autozone, they tested it, it was good. WHat can be the problem. I heard that pepboys carries some type of wiring that comes with relays and cesors (something like that) that helps you control your fan. Is this worth it? Thanx for any info!
92 Firebird 305 TBI
K&N Open Air Element
K&N Crank Case Filter
Just a begginer, soon i will advance!
Old Nov 27, 2001 | 10:09 PM
89 rs305's Avatar
You can wire the fan to the ignition if you don't use the car in cold weather. You could also get an aftermarket engine driven fan
Why drive a mustang when you can embarass a mustang driver?
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
TheExaminer
Aug 26, 2015 04:59 PM
kyleb24
Aug 15, 2015 08:24 AM
Kaweh
Aug 9, 2015 02:54 PM
