305 won´t start
Old Nov 10, 2005 | 10:58 AM
warheart's Avatar
Car: `84 Trans Am, `78 Monte Carlo
Engine: 350 TPI, 454
Transmission: T5, TH350
Axle/Gears: 3.23, 3.42 posi
305 won´t start
Just installed a new flat tappet cam and new lifters. We set a timing with timing light. The engine turns nicely but it won´t start. I checked for the spark and it turned out to be ok but the plugs were wet. Sometimes it poped to the carb sometimes it banged to exhaust.
It`s a carbed engine with 600 cfm edelbrock carb and blue holley fuel pump. The fuel pressure is about 6psi...
Old Nov 10, 2005 | 11:07 AM
Distributor is 180 degrees off
Old Nov 10, 2005 | 11:14 AM
warheart's Avatar
i checked it and it wasn´t....
Old Nov 10, 2005 | 11:17 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
If you installed your timing chain set at dot to dot alignment, but installed your distributor pointing to the #1 cylinder and set it up as such, then yes, you are 180° off. At dot to dot alignment, the #6 cylinder should be recieving spark.
Old Nov 10, 2005 | 11:18 AM
That's what that all say....
Until they turn it 180 degrees and the car starts.
Old Nov 10, 2005 | 11:29 AM
warheart's Avatar
Yes, that´s exactly what we did. I´ll try to turn it.
But is there also a possibility that the valves are set wrong?? We installed new anti pump-up lifters and i´m not sure if the valve lash is correct. ..
Old Nov 10, 2005 | 11:33 AM
Zero-lash them, and final-adjust them after you get the car running. THen they won't matter.
Old Nov 10, 2005 | 11:52 AM
warheart's Avatar
Thanks for the fast replies. I´ll go and try my luck
Old Nov 10, 2005 | 04:42 PM
warheart's Avatar
Well the same problem continued although i double checked everything. Finally i screwed on 750 speed demon and it cranked!! This carb looks brutal on a small 305, but it must run with it until i´ll get my 600 refreshed.
Jake_92RS
Jan 28, 2020 10:37 PM
apo_bailon15
Mar 28, 2016 05:20 AM
justin57
Aug 20, 2015 07:05 PM
drathaar907
Aug 6, 2015 04:20 PM
