Firing order???
Old Nov 11, 2005 | 06:05 PM
russ howe's Avatar
Car: 89 IROC vert
Firing order???
What is the firing order for an 89 305 TPI?
Old Nov 11, 2005 | 06:07 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
18436572 just like every other GM V8.
Old Nov 12, 2005 | 11:20 AM
russ howe's Avatar
Car: 89 IROC vert
Thanks, Stephen,
I have worked on cars since the early 70's and the firing order has been 18436572. I felt that it has not changed but I was not sure.
My IROC slipped off of the floor jack and damaged my oil pan. I replaced the pan, but I can not get it to run right. I replaced the distributor as I felt I might have bent it when jacking up the motor. I did remove the cap for clearance prior to jacking up the motor. The distributor turns counter clockwise, right?
Russ
Old Nov 12, 2005 | 11:33 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Clockwise.
KCG
Jun 24, 2020 04:33 AM
djmarch
May 8, 2016 11:32 AM
camarohelp
Sep 22, 2015 03:19 PM
webeeZ28
Sep 14, 2015 12:00 PM
