time to beef up the car
Old Nov 27, 2001 | 11:20 PM
JunkHead84's Avatar
time to beef up the car a bit, here are the current mods i have not too many. 86 350 crate motor, edelbrock performer intake, edelbrock 650 carb,ported heads, dynomax headers ( noting behind them ) 160 thermostat, no ac, edelbrock open element, accel supercoil, turbo 350 tranny, 342 limited slip gears and thats about it, everything that i didnt list is stock, gimmie suggestions guys, thax
Old Nov 28, 2001 | 12:22 AM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
Beef up the suspension. Good struts and shocks like KYB's, SFC's and LCA's. Perhaps bigger sway bars or even a wonderbar up front
Swap out those crappy old rubber bushings for some good poly stuff. It makes a world of difference in handling and 60ft times.
Rob P
89RSconvtZZ4TPI Edelbrock Intake
SLP Dual Cold Air Intake 1 5/8" Headers Semi-Siamesed Runners, IROC
suspension, alum shaft. Numerous mods.
92Z28convt5spd (stock)
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
Old Nov 28, 2001 | 09:19 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Get yourself the Hooker cat-back, $200 and can be welded on. Maybe a higher stall TC as well.
2 Tickets to game= $250
Gas= $20
Sitting 20ft. from MJ= Priceless
'86 IROC T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK HEADERS Hooker CatBack
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat, just switched to 180* b/c of winter coming and going to college in the mts.
3:73 Posi Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
Old Nov 28, 2001 | 09:33 AM
85transamtpi's Avatar
When you say "crate motor" what do you mean? Hows the cam? If is a standard 350 replacement motor, you could probably benefit from a cam swap. What kind of heads are on the motor(I can only guess with your username)? Swapping these for a nice set of aftermarket heads can make a HUGE difference. Definetly run some exhaust of some kind. Do you have a Y-pipe for the headers? I guess I need more information about your engine.
Old Nov 28, 2001 | 10:04 AM
Car: 99 Formula
Axle/Gears: 342
If you got the GM Goodwrench like I do, be careful about changing the heads or cam to not void the warranty.
Old Nov 28, 2001 | 10:14 PM
JunkHead84's Avatar
it has stock heads and a stock cam. theres no y pipe for those crummy dynomax headers, i was gonna have 1 made because i had no alternative. thanx
Ghettobird52
Jul 5, 2024 11:18 PM
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Linson
Aug 21, 2015 02:12 PM
