idle problem
Old Nov 22, 2001 | 06:57 PM
Vikingbrew's Avatar
idle problem
this one might be tough to explain...
half the time on a cold start, the engine light comes on and the car is idleing at 1200-1500. so, when you put it in gear the tranny suffers. Plus when you come to a stop, the brakes are suffering cause the car wants to pull forward(cause of the high idle)
i dont have a code reader and dont wanna pay an hours labour for it either.
help now
there's no replacement for displacement
Old Nov 22, 2001 | 07:36 PM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
<font face="Verdana, Arial" size="2">Originally posted by Vikingbrew:
help now
</font>
If you have an '82-'92 Firebird or Camaro, which I'm assuming you do because you're on a thirdgen camaro/firebird website, then you don't need a code reader to get your codes. Find your ALDL box located under the right side of the steering wheel and remove the cover. Take a paper clip and make a U shape out of it and plug each end of the paper clip into the top two terminals on the top row, far right. Once that's in place turn your key to the ON positions, do NOT start the car. With the key in the on position watch your Service Engine Soon light. All codes are two digits and the light flashes the appropriate number of times for each digit. 12 is normal and will flash first.. you'll see one flash for 1 and then a short pause and then the light will flash twice for 2... that's code 12. It will do this 3 times and then it will start flashing the codes that are stored in the ECMs memory. Count the number of flashes to get the two digit code. The trouble codes will flash 3 times as well and then move on to the next code if there is more than one. If not then it will start flashing code 12 again to let you know that's all the codes. Take the code(s) that you got using this method and either A. look them up in a Haynes or Chiltons manual or B. Call your local parts store and they should be able to look the code up for you.
To clear all codes from your ECM, unplug the battery and leave it unplugged for a couple minutes... this will clear all codes. If you unplug your battery before you start to extract codes then you will NOT be able to get your codes from the ECM. If this happens then start the car and wait for the SES light to come on again and then shut the car off and then extract the codes.
1986 Trans AM
355 TPI
4 Wheel Disc Brakes
9 bolt Borg Warner Rear (2.77's....oh joy) :P
6" rods, approx. 9.7:1 Compression, Stock TPI (soon to be ported), 24#/hr LTI injectors (cleaned and flowmatched by Cruizin Performance), Hedman Shorty Headers, 3" exhaust with 80 series flowmaster, SBC 993 heads completely redone and modified for 1.6 RR, 1.52 RR (for now), Comp Cams XE262-14 TPI Cam, Holley AFPR, TPIS airfoil, MSD wires, MSD 6-AL Ignition, Hypertech 53,000 volt coil.
Track times to come.
Old Nov 22, 2001 | 10:56 PM
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
Have you checked for vacum leaks?Those can cause a high idle.Check every rubber hose througly.
Old Nov 23, 2001 | 01:05 AM
Enkil's Avatar
If it's cold, the computer is going to make the engine rev higher anyways.
However, it might be a good idea to check the TPS and the IAC. There's a technical article about this.
89 iroc-z 305 tbi
k&n filtercharger, open element air filter. nuffin' else
Old Nov 26, 2001 | 11:37 AM
Vikingbrew's Avatar
it flashed 32, 33, 34, 46 and 52.
im guessing that there are old codes in there and have just disconnected the battery. i guess the only thing to do is wait for a code to show and plug in the jumper wire...
Old Nov 29, 2001 | 12:45 PM
Vikingbrew's Avatar
it only flashes code 54 now. the idle problem is really ****** my tranny...
i tried the both adjusts next to the intakes and the lowest the idle will go is 1000rpm.
plus the tach is spiking(the car idles fine, but the gauge is spiking all over the place)
help me now...
Infested
May 22, 2018 11:56 PM
db057
Aug 22, 2015 08:17 PM
zeitghaist
Aug 18, 2015 07:33 AM
perZ
Aug 15, 2015 01:17 PM
