Tips on rear shock install........
Old Nov 29, 2001 | 03:56 PM
BowtieFever's Avatar
I have already put new struts on my car. I hear the shocks are a little easier to do. I ordered Lakewood 50/50 drag shocks. Is the install pretty-straightforward? How should I jack the car up and what end of the shock should be removed first?
92 Camaro RS
305 TBI
T-Tops
DynoMax Cat-Back Exhaust
Gutted Cat
Hypertech Street Runner Chip
K&N open element
Custom Interior
Window Tint
Prestige Alarm
Foglights
JVC El-Kameleon Head Unit(w/ remote)
Pyramid 6 x 9's
(bass blockers)
Jensen 5 1/4's
2- 10" Kenwood Tornado Subs
Pyramid 600 Watt Amp
Best ET: 15.976 @ 86.01 mph
reaction time: 0.479
60 ft: 2.269
Old Nov 29, 2001 | 04:07 PM
irocbsa's Avatar
Do them one at a time and loosen the bottom end first. Don't take the bolt out, just loosen it so you can spin it freely with your fingers. Then do the top. Pull it out and reverse the procedure. I think the bottom bolts go to 60 lb ft and the top to 15. Very easy job. The only thing that pained me was getting the carpet back in straight.
bsa
"If they do not run, Then they will die." - Stonewall Jackson
'87 IROC, 355 TPI, Converted to SD, 700R4, B&M Megashifter, 3.42, Trick Flow Twisted Wedge Heads, Edelbrock Intake, Accel Runners, Comp Cam, Crane Gold rockers, Lucas 24# injectors, Edelbrock headers, Flowmaster 3'' exhaust, Mallory Ignition, Shift Kit, Corvette Servo, 2,000 Stall Torque Converter
1991 RS, 305 TBI, T-5, Bone stock daily driver.
Old Nov 29, 2001 | 04:55 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Raise the car by the diff with a hydraulic jack, place jackstands right in front of the rear control arms, on the "pads" there. Then, after you break the lower shock bolts free (might need a back-up open-ended wrench on the other side to keep the bolt from spinning), start lowering the axle slowly. You'll find a "sweet spot" where the lower bolts just "push" out of the axle; you might need a slight tap with a hammer. (You shouldn't be pounding them out.)
I thought the lower shock-to-axle bolts got 90 ft/lbs torque?
Carpet tip- if you don't mind the extra work, remove your rear folding seat-back with a 10mm socket & ratchet (one nut in each extreme corner). Then remove the rear seat bottoms with a 10mm socket- they each have one bolt holding the bottom to the floor, at the "front center" of the seat bottoms. The backs of the seats are held with velcro to the rear cargo-area carpet. With the seats out, it's much easier to work with the carpet- and it only takes 5 minutes to undo the seats. Just remember not to put the seat-bottoms back in so they cover up the seat belts!
-Tom P (Hot rodded 1986 Firebird 2.8l)
customblackbird
Aug 15, 2021 10:16 PM
NORTz89
May 20, 2020 03:51 PM
LT1Formula
Nov 16, 2015 01:13 PM
kevyb1973
Aug 24, 2015 04:11 PM
1992 Trans Am
Aug 9, 2015 04:32 PM
