car died tonite, im buffled....
Old Nov 26, 2001 | 06:59 PM
daniel dekay's Avatar
for about a year and a half she's been running great. but today on the way back from school it stuttered then died, i had to pull off the road. i waited for about 10 minutes, attempted to start her again and she fired up then died almost immediately. then it just wouldnt kick again. it just whines and whines like the batterey is dead.
-things ive checked so far..
battery terminals
all connections
leaks
ran for codes...got a 24, then 12 and 24 repeated
i think my sig will show what i have in my car, but im not sure.
thanks in advance
daniel
86 camaro cpe(dont laugh)has 92z28 body kit with GTS covers, new red paint and a killer stereo. 2 amps, 8 speakers, disc changer, custom install with subs coming by the end of the summer. gm 350,TES headers, flowmaster cat back, performer manifold, TCI converter, jet chip, kn with dual snorkel cleaner. and she still passed the sniffer!
"Cal Poly SLO is the shi#"
Old Nov 26, 2001 | 07:13 PM
86z/92rs's Avatar
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
Have you checked your ignition coil?
Old Nov 26, 2001 | 07:52 PM
thats what i was thinking, but then i got too dark and i have to work on it outside and blah blah blah.
how do i go about checking that?
thx for the speedy replay.
daniel
Old Nov 27, 2001 | 03:05 PM
ok, i replaced the coil. it started for a about 10 seconds, then when i went to rev a little higher it stuttered then died. and i cant get it started. it just cranks but wont turn. so does that mean its the module that needs to be replaced?
thanks
daniel
Old Nov 27, 2001 | 03:06 PM
thanks
daniel
Old Nov 27, 2001 | 07:13 PM
86z/92rs's Avatar
Still died even when you replaced the coil? Take the new one back to the store and get your money back. What type of motor do you have? Is is carb or FI? As far as a code 12, that is normal and a code 24 would deal with your vehicle speed sensor.
Old Nov 27, 2001 | 07:27 PM
yep still died, but this time it fired up at least. thx for the code info.
350 ci, 4 bbl qjet and 700r4.
daniel
Old Nov 28, 2001 | 06:09 PM
i replaced the ignition module as well and it still wouldnt go. it started for a moment then died and i couldnt get it back. what else could be the problem?
thanks
daniel
Old Nov 28, 2001 | 07:03 PM
86z/92rs's Avatar
Next time you try to start it, take the air cleaner off and see if you are getting any fuel when you turn the car over.
Old Nov 28, 2001 | 11:18 PM
Fred91TA's Avatar
Car: 1991 Trans Am
Transmission: 4L60
Sounds like a fuel pump to me.
91 TA 5.7 TPI Automatic
w/WS6 and 3.23 rear.
K&N Cone Air Filter (at the end of the plastic tube), Hypertech Coil, Moroso Blue Max Wires, Bosch Platinum plugs, JET 180*fan switch, JET air foil, Dual cats with Flowmaster 3" cat-back, GM Performance PROM, Complete PST components on front suspension, Spohn LCAs/Panhard bar.
My car only uses Mobil 1 synthetic fluids.
Old Nov 29, 2001 | 08:40 AM
VampireHunterC's Avatar
Sounds like maybe the ecc computer going bad? Wait, do ThirdGen's even HAVE ecc computers, or is that just a Ford thing?
Old Nov 29, 2001 | 06:28 PM
86z/92rs's Avatar
You could also try putting starter fluid in the carb since you have a mechanical pump.
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
killer777
Aug 8, 2015 02:47 PM
