Car won't start
Old Nov 30, 2001 | 12:25 AM
Team FTS's Avatar
Car won't start
Here is my dilemma the bottom radiator hose disconnected off of the engine the car's temparature got to about 260* and died I reconnect the hose fill the car with anti-freeze and water now it won't fire the motor cranks but it won't start.
P.s. I drov without water for aboout 1min. and also I did not the hose came off
Old Nov 30, 2001 | 01:50 AM
DANIELEK's Avatar
Car: Red Rooster
Transmission: M5
In order for any vehicle to star is the need of all three basic ingredients:
- oxygen
- fuel
- spark
If any one of them is missing your car will not start.
Things to check for would be your secondary ignition, if you have a MAF unplug it and then try to start.
Check your fuel pump. Is there pressure in the fuel rail. If there is not then the pump is gone.
Check everything carefully. I bet it is the fuel pump because they die without many/any previous signs.
Good luck
89Iroc, 305 TPI, WC T5, 3.08 Posi, Flowtech Headers, 3 inch over the axle, Flowmaster 80, Aluminium Driveshaft, Ported Plenum, Air Foil, K&N, AFPR, Smog/AC/Cat Delete, 3300lbs, All free mods
Old Nov 30, 2001 | 09:23 AM
Team FTS's Avatar
I hear the fuel pump and injectors pressurizing so i doubt it's them, and I found water in the oil so i am gonna go with it being my head gasket or worst yet my heads
midge54
Dec 27, 2019 04:14 PM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
ZsTransAm
Aug 11, 2015 07:30 PM
killer777
Aug 8, 2015 02:47 PM
