Jacking the camaro up
Old Nov 29, 2001 | 09:32 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
i need to know how i can jack my camaro up high enuff so i can do an engine swap at home
its a 5 speed so i will need enough room to access the clutch
i'm sure there must be a way besides digging a pit in my garage
also what SPECIAL tools would i need for an engine swap??
torque wrench, clutch alignment tool, hydraulic clutch line puller, engine hoist
what else????
i have a pretty good amount of tools at home since i am going to school to become a mechanic
Old Nov 30, 2001 | 07:26 AM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
I may be wrong, but you will probably need a lift. Using a jack on these cars are tricky because of the low clearance and position of the frame rails. Its even worse if you have a fat-a$$ Y-pipe like I do.
You might be able to do the job with wheel ramps. I'm sure someone else here can give you more info.
For special tools: engine hoist & torque wrence will be a must.
ORIGINAL OWNER
92 Camaro RS, LO3, 5-spd, T-tops
Performance:
K&N Open Air Filter, Partial TBI mods, Edelbrock performer TBI intake, Fastchip Prom, Timing +4 degrees, Centerforce clutch, Xact 8mm wires, SLP 1 3/4" Headers (coated), Flowmaster Catback Exhaust, Richmond 3:42 gears, Torsen HD Posi
Sights & Sounds:
Alpine 8030 Alarm System, Valentine One Radar Detector (How did I ever drive without one?), Pioneer DEH 7450 Head Unit w/6-pack CD changer, Pioneer DEQ 7600 Sound Processor, 2 Kenwood KAC-846 Amps powering 2 12" Pro Red subs, 2 Pioneer 6x9 and 2 MTX 4x6 speakers. Spectre valve covers and accessories, Z28 grille w/aftermarket lights, MacEwen whiteface gauges
NEXT UP: the rest of the TBI mods & Suspension upgrades
Old Nov 30, 2001 | 09:05 AM
leirch's Avatar
You should be able to pull the motor out without the car even being off the ground. I did. But I pulled my 5spd out first and the engine(much easier).
Brendan
1987 IROC-Z, engine, tranny, and other "stuff"
Old Nov 30, 2001 | 09:09 AM
86Chicken's Avatar
I used a regular floor jack to put the car up on railroad ties. Just keep adding blocks on the jack to get it high enough.
I think I used 3 courses of ties. It was plenty high enough to pull out my 700R4 on a tranny jack. If an auto can come out, a T5 will definately do it.
Edit: Take the engine out with the tranny if you can. It will be much easier.
Dale
1986 FireBird
[This message has been edited by 86Chicken (edited November 30, 2001).]
Old Nov 30, 2001 | 01:40 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
When I dropped my trans down, I just raised it as high as I could, in all four corners, using my jackstands. I had no trouble getting under there, or getting the trans out.
When I did a 2.8/2.8 swap for a friend (pictures! http://www.geocities.com/tomp_3rdgen ), we raised the front of the car, and broke free the trans-to-engine bolts. Then, we lowered the car to the ground, put a hydraulic jack under the trans (with a block of wood between the jack and trans pan), removed the trans-to-engine bolts, removed the motor mount thru bolts, and yanked the engine.
So we didn't use any other tools than the ones you mentioned.. and we didn't even need clutch alignment stuff.
-Tom P (Hot rodded 1986 Firebird 2.8l)
Old Nov 30, 2001 | 08:43 PM
iroc5speed's Avatar
you can get to the clutch by putting the car on jackstands. the engine also does come out from the top, so you won't need to raise the car for that. Fairly straightforward. I think you may be able to do all the clutch work with the engine and trans out of the car and then install it all backas one unit. At least it seems logical to me.
'86 IROC 5-speed
305 LG4
edelbrock performer rpm intake
edelbrock 600 cfm carb
msd pro billet hei distributer
'95 3.23 rearend
hotchkis rear suspension
PST front polygraphite suspension
"speed kills. buy a f@&d, live forever."
Old Nov 30, 2001 | 11:58 PM
thanx for all your help guys!!!!!!!!!
i figured there was a way to do it
and that definetly makes sense to me!!!!!!!
our T5's use hydraulic clutch linkage right???
now here's the kicker
i am swapping from a V6 to a MILD 350
i know all the comments i am going to get about the tranny but all i can say is I KNOW I WILL PROBABLY BLOW IT THEN I HAVE A GOOD EXCUSE FOR A T56!!!!!!!!!
but i am doing a total carbed 350 swap
i am going to get the GM goodwrench 350 crate engine with something like 250 HP for $1300
what will be a good carb to use????
i think 650 cfm will suffice but what one???
and what kinda choke and all that stuff
what do i do with my purge cannister???
i know it has a two piece Rear Main Seal so what kinda flywheel and pressure plate will i need?
what would be a good ignition set-up????
i'll prolly get rid of the stock manifold and get an Edelbrock
and i'm also gonna get rid of my A/C since i never use it anyway
then i am planning a T56 and a posi/disc/ 4.11 rear end
i am basically gonna build up a nice fun car for myself
i'll also need some sub frame connectors
but i'm not planning on racing the car once i get the engine in
after i get all the other stuff yeah
i also need to move a brake line
and new front springs
headers
new radiator
new motor mounts
what accessories that i currently have can i keep???
i think i will need a new P.S. pump
i think my altenator will work
and how should i wire my fan???
thats another thing i am going to do
upgrade to a dual fan unit
no computer crap
dont care about emissions
anything else i forgot to cover???
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
69 Six Pack
Oct 5, 2015 07:51 PM
Amillionoh7
Aug 7, 2015 01:24 PM
