85 mph/145 mph speedos, whats different inside?
Old Dec 1, 2001 | 03:32 AM
EO273KiD's Avatar
Sup, i broke the needle off my 145 mph speedo, so i left the face plate off and now im driving around watching the magnet spin... i was wondering if i took an 85 mph speedo or 120 mph or whatever the lower one is and changed the faceplate, if it would be accurate... whats the difference between the two?
im assuming the speedo cable spins at the same rate and the 85 mph or whatever speedo pretty much fills the entire range across the face plate, so is the cup part farther away from the magnet or is there a difference in the cables themselves?
there are lots of 85 mph speedos around, butnot as many 145 mph...
Old Dec 1, 2001 | 01:35 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
All speedometer cables spin at the same rate for distance covered - therefore, at the same speed, two different cars will have their cables spinning at the same speed (in a perfect world, anyway).
It's what the different speedos do with the input that is different. Magnet strength, spring strength, distance, damping, etc., are worked together to make the speedometer read properly for a given vehicle (or cable rotational) speed.
Why not just replace the needle?
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4, 2300 stall TC. Ported World 305 heads, Crane PowerMax 2050 cam. ZZ3/4 intake, oil pump, pan & baffle. Accel HEI SuperCoil & module. Hooker 2055 headers, 3" Catco cat & 3" catback w/dual-opposite Flowmaster 80. 2.93 limited slip. Spohn SFCs waiting to be installed. AMSOIL syn lubes bumper-to-bumper. Daily year-round driver. Best ET, speed TBD...
57 Bel Air, my 1st car. '66 396, 9.7:1 forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 700 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
Elephantismo
Feb 13, 2019 12:51 AM
dbrochard
Exterior Parts for Sale
Oct 10, 2015 01:03 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
TrevinE
Sep 14, 2015 03:20 PM
