Hardened Pushrods
Old Nov 15, 2005 | 09:33 PM
littlezac's Avatar
Car: 84 Firebird
Hardened Pushrods
I read that if you use guide plates you're supposed to use hardened pushrods. I also read that my 305 heads don't need guideplates because they already have somewhat of a guide already in the head. So if i was to put guide plates on my heads anyway, would i need to replace my pushrods or are they already hardened.
Old Nov 15, 2005 | 09:43 PM
roughskinjrz's Avatar
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
stock pushrods arent hardened. correct me if im wrong.
Old Nov 15, 2005 | 10:00 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The slots in the head serve the same purpose as the guideplates. The pushrods have to be hardened to keep them from being worn through. Non-hardened pushrods can only be used with self-aligning rockers and no guideplates or slots in the heads.
Old Nov 15, 2005 | 11:04 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
only one type of pushrod alignment should be used, either the slotted holes in the heads, guideplates, or self aligning rockers, not 2 or 3 at a time.
Old Nov 15, 2005 | 11:21 PM
littlezac's Avatar
Car: 84 Firebird
I'm not going to use more than one. I'm going to use guideplates and drill out the old guide holes. I wouldn't have bothered doing it but my engine machining teacher told me i needed guide plates before i realized the heads already had guides. Its just as easy to go ahead and use them as it is to send them back.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
grngryoutmyway
Oct 18, 2016 05:48 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
slowsi
Oct 18, 2015 08:49 PM
mfp189
Sep 27, 2015 09:25 AM
