Taylor plug wire ends?
Old Nov 16, 2005 | 06:49 AM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
Transmission: THM700R4
Axle/Gears: 10 bolt, 3.23 non-LS
Can anyone tell me whether the this (TAY-74607)Taylor wire set has the distributor ends that fit in the coil-in-cap keeper. The picture in this link is generic.
http://store.summitracing.com/defaul....asp&x=44&y=16
I want an end like the attached picture.
Old Nov 16, 2005 | 09:49 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
don't know for sure they should. tay-73051 does
Old Nov 17, 2005 | 09:41 PM
Zed'er's Avatar
Car: 84 Z28HO
Engine: 350 summit block
Axle/Gears: 3.73 10bolt
It says:
Distributor Plug Ends: Male/HEI
Sometimes summit will use the same pic for multiple items from the same manufacturer.
Old Nov 17, 2005 | 09:51 PM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
Male/HEI could be coil-in-cap or remote coil, correct?
Old Nov 17, 2005 | 09:57 PM
Zed'er's Avatar
Car: 84 Z28HO
It says they are for use in 82-86 Camaro's, which came with satndard HEI distributors. (and 101 other GM vehicles)
They have a tool-free number, let your finders do the walking.
Old Nov 18, 2005 | 09:33 AM
http://www.taylorvertex.com/hp/Spark...Terminals.aspx Scroll down to Distributor/Coil Boots, look at the pic of a 46055, that's what should be on that set. Seems like I have 74007 on mine (same thing as you want except black), fits fine, but I haven't opened the hood for a while so I don't recall for whether they have the little nipple for the retainer ring. Pretty sure they do though.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
Infested
May 22, 2018 11:56 PM
Derick15
Sep 17, 2016 05:28 PM
