brakes
Old Dec 1, 2001 | 07:55 PM
hot86z-28's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Transmission: 700R-4
brakes
my brakes seem to pull to the right quite a bit, i thought it was jus they were bad so i had them completely redone, i mean everything. but for some reason it still does it, anybody know why?
86 sc z-28
305 ci around 150 hp prob lil more
my first car and the best one i will ever own.
Old Dec 1, 2001 | 08:01 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
What does "everything" consist of?
Could be a wheel/alignment problem.
If you live in Southeastern US, check us out!
South East Thirdgen
1987 Trans Am 305
14.88 @ 92.81
Old Dec 1, 2001 | 08:15 PM
hot86z-28's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
they said that the previous owner had not taken care of it and they had redone the brakes consisting of everything, as i recal rotars, discs, lot of other stuff
Old Dec 1, 2001 | 08:30 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Unless that "lots of other stuff" consisted of brake lines, I would certainly invest in some. Steel Braided if you can afford it.
South East Thirdgen
1987 Trans Am 305
14.88 @ 92.81
Old Dec 1, 2001 | 09:10 PM
chevymad's Avatar
Car: 87 Formula
Engine: 327
Did you do the rear brakes too? Not sure about your car but many have diagonal brake systems now. 1 front brake and one rear on the opposite side work on 1/2 of the master cylinder. If you have a leaking or stuck rear wheel cylinder it will increase or decrease the braking on the corresponding front wheel. Had this problem too. Replaced all the hoses and calipers and everything up front and was still there. Finally checked and replaced the rear cylinders and the problem went away.
Old Dec 1, 2001 | 09:35 PM
hot86z-28's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
i believe they did brake lines but not positive so i will not say for sure. and yes they did all four brakes on this job. i will look into some steel braided, how much they run??
86 sc z-28
Old Dec 1, 2001 | 09:43 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
I think Jegs sells Earl's for $78 for the front pair.
Diagonally split brake systems are on FWD cars, not RWD.
South East Thirdgen
1987 Trans Am 305
14.88 @ 92.81
[This message has been edited by GMTech (edited December 01, 2001).]
BADNBLK
Convertibles
Sep 21, 2015 07:56 PM
dbrochard
Sep 19, 2015 08:13 PM
Necron
Brakes
Sep 14, 2015 12:45 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
