gas smell inside the car when accelerating
Old Nov 30, 2001 | 08:22 PM
johndinu's Avatar
Car: '89 GTA 350 hardtop
Hi
When accelerating hard with the ventilation on I can smell gas... My car is a '89 GTA 350 tpi. Engine is stock (100.000 miles).
Should just verify the hoses for leaks?
Thanks alot!
'89 GTA
Flowmaster animal
Old Nov 30, 2001 | 09:18 PM
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
Do you have the hose from the airvents to open it to full blast,cant remember whats its called.But if it is connected to the back of the plenum you will smell some of gas,or at least i'm pretty sure of it.
Old Nov 30, 2001 | 10:06 PM
johndinu's Avatar
so it's nothing i should be woried about?
thanks!
'89 GTA
Flowmaster animal
Old Dec 1, 2001 | 02:08 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
You also might want to consider replacing the gas cap. If the pressure in the tank is not venting properly it makes a very strong gas smell in the car.
SSC
Old Dec 1, 2001 | 05:12 PM
socal85tam's Avatar
Car: 1988 IROC-Z
Engine: 383 HSR
Transmission: 4 speed Automatic
Axle/Gears: 4:10
I would recomend you to go and buy a small fire estinguisher and cary it in your car while you find the problem. Good luck.
Old Dec 1, 2001 | 09:59 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
I second the extinguisher idea...... It's a damn shame to watch someones pride and joy go up in flames and not be able to do a friggen thing about it......
1987 GTA L98 MD8
355, TFS Heads, LT4 Hot Cam
My GTA
The Minnesota F-body Club
bryan623
Mar 22, 2021 06:43 PM
mustangman65_79
Sep 1, 2015 03:51 PM
AkDrifted
Aug 17, 2015 07:45 PM
mustangman65_79
Aug 11, 2015 03:17 PM
